The scanner will stop and start between pages when scanning with Adobe X
SOURCE: DR-9080C intermittent stops during scanning which last 3 to 5 minutes
Do you have enough hard disk space? Reinstall your driver software. Run Scandisk on the Comp.
Is the problem coming on after a set time interval, any heating smell?
S. Mohan
SOURCE: Canon Dr-5020 grabbing multiple pages
Wipe the rollers with a damp cloth thoroughly. Remove all the dust in the glass for a claen scan. The red color roller roller in the bottom needs thorough cleaning, rotate with hand gently (in power-off mode) and clean it thorughly. No solvents pls, except Isopropyl alcohol for cleaning
S. MOhan, Chennai, India
SOURCE: Canon DR 2580C Scanning issue
In Captureperfect, select page size as 'Scanners Maximum'. Select automatic paper size, check the output now. If you select bigger paper size and smaller paper, you will see lack output, outside the paper area.
S. Mohan, Chennai, India
SOURCE: Acrobat and Canon DR-9080C not working
You are right, it is driver related issue. Acobat 9 has more features that may not be compatible with the existing driver. may be you can use CapturePerfect and directly create PDF and then use the Optimising features of Acrobat 9. Ofcourse you have to do it twice, but you can use the 'batch' process and do it automatically.
S. Mohan
SOURCE: Getting vertical lines on scanned pages when
It is dust on the glass, clean it thoroughly. You will find it at the same location for all drawings and may get faded for lower brightness!
S. Mohan
