Hi i have problems with a 45 model. it will start and run at full throtle but as soon as the revs drop the engine stops. I guess its a petrol problem but I don`t know exactly. Any suggestions please?
Could be a fuel starvarion problem. Theres one thing you could try before you try stripping and cleaning the carb. Back off both tuning screws, and pull over till it fires. Then screw both back in and reset them to standard. H3/4 of a turn anticlockwise, L1 full turn anticlockwise. Then try firing it up again. Sometimes its enough to cklear any dirt in the carb. Failing that, Its a strip and clean.
http://www.ebay.co.uk/itm/Evinrude-Johnson-Mercury-Yamaha-Outboard-Motor-CARBURETOR-CARB-CLEANING-TOOL-/261167700551?pt=Boat_Parts_Accessories_Gear&hash=item3cceceda47
These carb cleaning tools are great, but you have to know where and where not to be putting them. Certain parts of Zama carbs and Walbro carbs have tiny valves within the carb. So be carefull.
SOURCE: Husqvarna 40 Chainsaw won't start
The carb uses the pulses from the crankcase to actuate a diaphram in the carb as the fuel pump.If you strip the carb make sure there are no perforations/cracks etc. on these diaphrams and check too that the valve flaps are OK.if not fit a carb kit.
Also check that the pipe or channel from the carb to crankcase is OK.
If all this is correct you can simply put your hand behind the carb or inlet to check for vacuum if not there you have probably blown a crank seal(but unlikely)and you will have to replace them.
Hope this helps,and please come back if you need any further assistance.
Testimonial: "Thanks again luckyluke I did find it and was able to clean it through I'm still having the problem of not starting though, carb kit next 90lb cyl comp"
SOURCE: need initial carb adjustments for both high and low adj.
start at 1turn out on both that should grt it running from there..
SOURCE: poor performance at hi revs on poulan 3314
Try turning the high idle screw out 1/8 to 1/4 turn refer to your manuel for the location of this screw.
SOURCE: Husqvarna 345 chainsaw runs when using starting
Check the fuel lines for cracks/breaks. If they are o.k., then:
You willneed to disassemble the carburetor and spray with carb.cleaner.Makesure the small screen is free of debris. (Should be able to see daylightthrough it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
