I tripped while walking on the treadclimber in treadmill mode. My foot was caught in the middle between the two belts, and the belts stopped momentarily. I immediately stopped the machine, and got off. Once I restarted the machine and began walking on the belts. a loud knocking sound was heard coming from the bottom of the machine. I also see a red light on the right bottom side of the machine.
SOURCE: Noisy treadmill.
lose some weight -lol-its working for mine,cheers!-mine is noisy too-place a square of shaggy carpet under her- i find mine slips somewhat too even tightened-ok ill lose some more!
SOURCE: When walking in my Bow Flexn as in regular
If belt hesitates or slips when walking on unit it may be caused by either a loose walking belt or a loose drive belt. To determine the cause
perform the following test: Stand beside Tread-Climber® fitness machine and set speed to 2 MPH. Step on one treadle and attempt to stop
movement. If one belt stops but roller at rear and other belt continue to turn walking belt tension should be adjusted. If both belts stop but motor is still turning the drive belt tension should be adjusted.
Adjust walking belt tension at the front of the unit using the provided hex wrench on the exposed adjustment bolts located on each side of each
front roller. Be sure to adjust both bolts on each roller the same amount as to not disrupt belt alignment. Tighten (turn clockwise) each adjustment bolt in full turn increments. After each adjustment, restart unit and check to see if belt slippage has been eliminated. Repeat if necessary.
SOURCE: we canNOT get the belt
Can you describe your machine type (TC5000, for example) and what you've done to try and reposition the belt? Also which belt are you referring to? The treadle belt or the motor belt? I just went through a complete deck/walking belt replacement, and it's not for the faint of heart. Needed to dismantle almost 85% of the machine.
SOURCE: I am getting power to the treadclimber, however
hi,
ur treadmills motor controlling section have some problem. it have motor controlling circuit using igbt. maybe the igbt is open( faulty). also check the motor is its winding have some problem(it is raire). check the motor driving card. take care, the motor controlling card have high voltage points.
ok
