When I plug my Finepix into the computer, it takes a few minutes and does not copy any of my pictures to my computer. A little box comes up that says 'Failed to select device. Error code: 000000002h' It is an FTL Error Message. Then says my computer cannot read connect with my camera. I just got my computer fixed and it worked fine before then but now it does not.
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
SOURCE: device selection button locks up TV and after a
with the remote press menu2 4 7 0 enter this should reinitialize set when it has reinitialized push reset button on front panel this should cure it. You will have to reprogram your channels and net command though.
SOURCE: FTL: file src\hwb_init.c line 402 Boori init: Calibration failed!
For this problem, you have to contact Alvarion support. They may ask you to send it to their factory for repair. There is nothing you can do at your end.
my computer can not read fuji camera so what can i do
iconnected by usb cable but it can't be seen
