Televison & Video Logo
A
Anonymous Posted on May 12, 2017
Panasonic tx-26lxd8 Can hear sound but only a very faint picture
When I first turn it on it has a white/yellow screen with multi coloured lines moving across or down the screen. It is very psychedelic and as I can still hear sound I initially thought someone was trying to communicate with me through the TV. So for about 2 months I was writing down pieces of information trying to work out what the message was and if in fact it was human people or an alien species communicating with me. Eventually I realised it was just in fact a fault on the TV so here I am trying to fix it. Please help?
5 Related Answers
rainsocket
  • 32 Answers
  • Posted on Apr 02, 2009
SOURCE: Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
Anonymous
  • 80 Answers
  • Posted on Jun 01, 2009
SOURCE: Vertical white line down centre of Soniq PT42SH plasma TV.
One of your "X" buffer boards is defective. In Panasonic plasma tv's they are located at the bootom of the set and connect directly to the plasma diplay panel via a thin ribbon cable. The board you want to replace will be directly in line with the discolored vertival line in the picture. The part number is on the circuit board and usualy starts with "tnp..." or "txp..."
Anonymous
  • 3 Answers
  • Posted on Dec 12, 2009
SOURCE: philips 26pf3320/10
there is a get around for this fault if you locate panel v26c look at the bottom rh corner you will find 2 test points tp11 and tp 12 if you then look on the rhs of the lcd panel actualy mounted on the side (you will have to remove the metal frame from around the screen ) you will find another panel with 2 more points tp 506 and tp507 simply solder a wire link between tp11to tp506 and another from tp12 to tp507 and that should be a permanent fix to this problem
Raditronic
Radames Pagan
  • 196 Answers
  • Posted on Apr 22, 2010
SOURCE: Thick lines descending plasma screen
maybe you have interference with other electrical component near your tv. move the component, example cable box, dvd, sat box.
Anonymous
  • 16 Answers
  • Posted on Jun 05, 2010
SOURCE: Large colour lines / bands on screen
Thats your midddle driver board on the botton m8.
Try the technique on this video if that doesn't work ,replace the board by with another of the same part number.Cheap to buy.Ebay.LCDTV Spares shops online
http://www.youtube.com/watch?v=9NPobj0_GSo
Testimonial: "thanks so much for the info mate! The issue comes and goes so I will see how it pans out before I attack it with the soldering iron!"
1helpful
Panasonic LCD TV Modeel No: TX-26LXD8A has vertical coloured lines that change colour depending on the program/picture. It began with a vertical red line near the centre of the screen and now there is no...
Other than taking the television to a repair shop not much can be done. I recommend a new television. Excellent brands are Sony, and Samsung. Both brands are quality televisions. Best of all you can order them on Amazon.com for lower prices.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
You can hear the sound , just no picture on screen
I presume model number is correct---with sound after about 2 minutes if you see a faint band of white noise top to bottom to the right of the center of the screen (easy to miss) C509 is bad.
LG flatron plasma rz42px10 snow screen with sound
Check and replace its tuner. If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
1/turning the unit on the screen or panel is all white
You need to resolder the video IC processor they are one smd device
6helpful
2answers
2helpful
2answers
Intermittent 3 inch green vertical line-5 inches from right side
it you have a repair skills you need to open the TV and make sure all the ribon connectors around the circuit boards are proper connected
and if all seems to be ok, the DG board will need to be replaced.
If you dont have any repair skills I would recommend you to take you TV to a repair shop since this is complex repair
Trouble with my panasonic fz50
CAN YOU SEND EXAMPLE PICTURES, OR DESCRIBE THE FAULT IN DETAIL.
Tv showing blue screen with flyback lines sound ok
Flyback lines? Is the picture all white with no brightness control with faint horizontal faint lines? If this is what you are saying, the screen voltage could be bad, and if thats the case, the picture tube or the flyback itself could be bad. You could also have a bad connection on the crt socket
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
