I dropped my tablet on the bar of my computer chair its cracked and it wont respond to my touches. i tried turning it off and on but it wont do anything any suggestions
SOURCE: my android tablet is "frozen". Will turn on but
has anything been deleted from it when it has been plugged into a computer or has anything been deleted from the device itself from its root directory? if not and its gone like that by itself, it could be corrupted software or a missing root file which is usually bad at first, now what i know about some tablets is if it wont work theres a recovery file usually internally but this is in some tablets only that ive read about, i also have one but havent needed to try to restore it and it can be done from an engineering mode, this is possable by pressing the power button and another button like the home button at the same time once the unit is off untill it turns back on with options, but as for some models im not sure of but i will have to look this up at some stage as i am working on tablets at this time so unless you know what you are doing i wouldnt attempt it, once i have gotten through some tablets ill be able to give a better resolution on this subject with others. the advice ive given wont work for all as pressing power and home will start different options up on different tablets and versions.
SOURCE: How to hard reset Craig 7 inch touchscreen tablet
Most tablets can be hard reset by pressing and holding the power button down for 10-15 seconds. Give that a try.
SOURCE: Need to upgrade Android 2.2 to 4.0 on ZEPAD ZT-180 v2
If the manufacturer doesn't support android update on your tablet then you will have to go the unofficial way of doing it. Try this website
Www.xda-developers.com
