SOURCE: Check/add oil to a hunter ceiling fan
If you are asking for instructions on checking and possibly adding oil to a Hunter Original fan. Here are instructions:
Check oil level immediately after filling the reservoir. To check oil, bend an ordinary pipe cleaner into a 1/2" long hook and dip it into the oil reservoir.
If oil touches the end of the pipe cleaner, the fan has ample oil. If it does not touch, add SAE 10 non-detergent oil slowly until it touches the pipe cleaner.
-Hunter Original fans rarely/ never need oil unless they were relocated or tipped. ...Or if the fan was improperly installed.
-Hunter sells an oil refill / oil level check kit with good instructions. They also sell a relocation kit that includes the same kit plus all mounting hardware needed.
Good Luck!
SOURCE: Hunter ceiling fan-just installed -possible speed control problem
Sounds like the fan is defective. All internal wiring from the switch to the motor is factory installed. The fan has power going to it. Just to make sure, double check the wiring from the ceiling fixture to the fan.
Problem could be a faulty switch on the fan or faulty motor(bad winding for med. speed). Try reverse switch on the fan to operate the opposite direction and see if medium speed works. If medium does work in opposite direction, it pretty much points to a defective fan. In any case, unless you discover that the ceiling wires were reversed going into the fan, I'd say new fan to the returns dept.
SOURCE: I have a hunter ceiling fan (model #20537) which
Check with stores that sold it and see if they will warranty replacement. I think there is a lifetime warranty, thats why you pay the big bucks for the Hunter name.
SOURCE: Need a replacement capacitor
Voltage rating doesn't matter. 250v or 330v will work.
If this is really a 2 speed original, with the 2.5Amp motor... it will NOT have a capacitor as the motor is a shaded pole unit. The three speed electrically reversible fans, have a capacitor, which can either be in the switch housing/ oil reservoir, or the top of the motor housing, depending on year of manufacture.
SOURCE: Need to oil Hunter Ceiling fan, Tyep G model
There are only two places to lubricate a ceiling fan, the top and bottom of the armature that goes through the center of the motor. The blades in turn hook to this and rotate with it. The top of the armature, closest to the ceiling, is probably a little difficult to get at. The bottom of the armature is probably easier to get at. To do a complete job of lubricating both ends, the fan must be taken apart and cleaned of old lubricant which is then replaced with new. However, I have found that using a can of WD40 with the red extension nozzle is the best way to do it without taking the fan apart. Spray some WD40 at the lowest part of the armature supported by the motor housing. WD40 is better than oil because it penetrates better and it is less likely to cause a build up of dust and dirt that would cling to the oil.
After oil the fan is obviously to stiff to run any longer. I want to do the repair myself is ther anynoe out there who has been sucessful with this?
