Maytag EPIC MFW9700S Front Load Washer Logo
Debby Posted on Apr 18, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Maytag epic front load emits sewer gas odor with first drain
My Maytag clothes washer makes the laundry room smell like dirty diapers during the first drain/spin cycle. Is it my basement plumbing, emitting sewer gas, or the machine itself? Should I replace the drain hose in case poopy gunk is stuck in there?
Marvin
Level 3:
Top Expert:
  • Maytag Master 85,242 Answers
  • Posted on Apr 18, 2013
Marvin
Maytag Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29059417
Points
266281
They have cleaners available that will cure this problem.
3 Related Answers
Anonymous
  • Posted on Nov 12, 2008
SOURCE: maytag neptune front load odor
its better do a maintenance, or put it to wash without cloths, only water and clorox, and varsol with the max level (water)
BIKER T
Terence Fourie
  • 909 Answers
  • Posted on Sep 21, 2009
SOURCE: Maytag Epic Z front loading washer spin cycle very loud
your bearings and seal need to be replaced.
Paul Flynn
  • 34 Answers
  • Posted on Dec 24, 2009
SOURCE: The washer emits a foul odor when washer first
You have the beginning of a detergent and/or softener residue buildup on the inside of the plastic outer drum of your clothes washing machine. Mold and bacteria need a moist, dark environment and a food source to grow. This residue is the food source. This can be a major health concern. See: http://www.cbsnews.com/video/watch/?id=5408971n
We can't change the environment of the washer but we can lessen the "food source" by reducing detergent and fabric softener use.
Do an internet search on "Smelly Washer Reviews" to see what you can do about the problem of mold odor in your washer, towels and clothing.
After your washer odor is gone you'll need to change washing habits so mold and bacteria don't return. Go to the blog page at smellywasher.com to read the featured posts on the left side of the page on the cause of the problem and what to do for extreme cases of washer mold odor.
2answers
I occasionally have a sewer gas smell near my washer. But after I run the washer, the smell will go away for a few days. What could the problem be?
Hi Joe
Is that pex pipe on the right your water supply to the washer?
Your sewer gas smell I believe can be eliminated by putting a P trap in the drain PVC line.
(EDIT)
Where the drain hose from the washer hooks into the PVC pipe is NOT airtight which would allow the sewer gas back into the laundry room!
(EDIT EDIT)
If there is a P-trap in your outflow pipe, the only place left for grey water to collect (and stink) would be between the washer and where the waste hose goes into the drain. We've had to use a little bit of bleach on occasion when we haven't used the washer for a bit.
Hope this helps
-Steve
My maytag epic z is leaking from underneath
Remove the front bottom panel. Should be three 1/4" screws on bottom lip of panel. See if you can tell where leak originated. Chances are good you just need to pop the cap off the drain pump and clean it out. Here is a vid that explains the procedure.
http://www.youtube.com/watch?v=iLftnaruKp8
1helpful
2answers
Maytag washer model # MAVT236AWW Ser # 11354800GV This thing will not wash or drain or spin. It will fill up with water. I have smelled a burning smell and smoke filled the back room. To me it has...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
1helpful
Odor coming from washing machine - smells like sewer gas
The odor coming from your washing could indicate a problem with your
hot water heater or possibly your city's cold water supply line.
In some cases the odor might be originating from the drain located adjacent to
the washing machine. During long periods of inactivity, if no water is flushed
down the drain, a sewer smell will be emitted from the drain. To alleviate
this condition, just flush water down the drain.
I hope this helps you solve your problem.
1helpful
2helpful
Maytag Neptune washer has bad odor, city water.
There is no filter in your washer that would cover the odor issue.
The website link below will give you all the information concerning odors in a Maytag Washer
http://maytag.custhelp.com/app/answers/list/kw/odors/p/293/r_id/108284/sno/1/search/1/session/L3NpZC9RRDdZdDhEag==
1helpful
Maytag neptune front load odor
2answers
Disposable diapers
should resolve itself with repeated rinses
Dirty sock smell
My suggestion is to contact Maytag. I have the same problem. Maytag can tell you what you can do to reduce the odor. I think the problem originates from the fact that the drum always has water in it and the rubber seal has a bad smell.
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
