My PC (Dell) is connected to a Router (LinkSys WRT160N) via ethernet cable. My Laptop (Dell) is a wireless connection and works fine. When the Laptop is on, the internet connection on the PC works fine. However, when the Laptop is off, the internet connection will not work on the PC. The only way to get around this is to directly connect the modem to the PC.
Any ideas?
SOURCE: do i need a modem for my linksys WRT160N Broadband router
Greetings,
You need to have a separate DSL modem
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
SOURCE: Can't get wireless connection from PC to Linksys WRT160N
To setup a wireless connection on a computer, the wireless card in the computer needs to be configured with the wireless router's settings.
For instructions click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
SOURCE: My Linksys 2.4 GHz router no longer is getting us
The problem is with the router!! You should contact link sys for this!!! And get it checked by them.
I am running Vista on both.
I am on the road until Tuesday. I will have to check when I get back and let you know.
I appreciate your help.
sam for me. Linksys suggested hard coding the DNS bu that worked for about 5 minutes then it stopped working again
I show 2 dns servers. One ends in 7.10 and the other ends in 7.11.
about the same it all connected but i cant connect to aol which i have piggy back with internet explorer
will do what i can to help u out. good luck travel safe!
what are u using for your dns setting on your pc? you can check it by click start; run; type cmd; press enter
in the black screen type ipconfig /all then press enter
this will display the ip address of the dns setting. usually it should have the same ip address as the default gateway.
