The message could not be sent because the server rejected the sender's e-mail address. The sender's e-mail address was '[email protected]'. Subject 'Tester', Account: 'Perth', Server: 'cp11.digitalpacific.com.au', Protocol: SMTP, Server Response: '550 Access denied - Invalid HELO name (See RFC2821 4.1.1.1)', Port: 465, Secure(SSL): Yes, Server Error: 550, Error Number: 0x800CCC78
SOURCE: sending e-mail
Well, did you try going to the help website given? That would be extremely wise. ^-^ I went and it seems to answer many questions.
SOURCE: i have yahoo id i wand configure to my outlook
There was a problem logging onto your mail server. Your Password was rejected. Account: 'pop.mail.yahoo.com', Server: 'pop.mail.yahoo.com', Protocol: POP3, Server Response: '-ERR [SYS/PERM] pop not allowed for user.', Port: 995, Secure(SSL): Yes, Server Error: 0x800CCC90, Error Number: 0x800CCC92
make sure your password is correct because this error description states that your password is incorrect
SOURCE: Hi, this message appears and I can't receive
I do not like Outlook, it is not good, I choose to use IncrediMail, I think it is good, you can try this, reset the details, and it will not appear that problem. You can get it here:
http://softsbay.com/download/IncrediMail-3418.html
SOURCE: I keep getting the following when opening or
Quick summary:
It appears that email address does not exist - which is why your email program was unable to send the message. There may be a small typographical error in the address - which you would need to correct in order to send the message successfully.
Background:
The error message you received says the "domain does not resolve". That means your outgoing server (which is used for sending messages) couldn't find the information about the recipient's address -- and more specifically, the "domain" of the recipient's address. (That's the portion of an email address following the "@" sign.)
The error message indicates the domain of the recipient's address is "quickfireprocuctions.com". But a quick check of domain registration records indicates there is no registered domain by that name. And if a domain is not registered, there can't be any websites or email addresses which use that domain name.
However, there is a properly registered domain "quickfireproductions.com" (with a "d" rather than a "c"). That seems much more likely - as the combination of recognizable words ("quick" "fire" "productions"). That domain is registered to owners in Florida, USA. See details at: http://whois.domaintools.com/quickfireproductions.com
Solution:
If that registered domain name sounds right, then you should revise the email address in your message to use the correct domain name (i.e., replacing the "c" with a "d").
