Using USB cord, doesn't show up under scanned MIDI controllers.
Make sure you follow the steps of the procedure below exactly. Connecting incorrectly can make data
send and receive impossible.
1.
Turn off the digital piano and then start up
your computer.
• Do not start up the music software on your computer
yet
3.
Turn on the digital piano.
• If this is the first time yo
u are connecting the digital
piano to your computer, the driver software required
to send and receive data will be installed on your
computer automatically.
4.
Start up your computer's music software.
5.
Configure the music software settings to
select one of the following as the MIDI device.
CASIO USB-MIDI
SOURCE: Casio Privia PX-120 cannot be connected to Reason or FL
When you are using midi the sounds from your keyboard aren't sent anywhere. What happens is control messages are sent over the midi cable from midi out to midi in on the other device which must have midi sounds on it (in your case the sound card) to make any sounds. The messages can be things like note on/of or pitch bend etc. If you want to send messages to produce a result on your laptop and still here something you can loop the messages by running from midi out on the device end ( your laptop) back to midi in on your keyboard. A much better explanation is available here:http://www.indiana.edu/~emusic/etext/MIDI/chapter3_MIDI.shtml I also signed up to this site (its free) that has great people and lots of info:http://www.recordingreview.com/ I recommend downloading Killer Home Recording setting up which at this time is also free and has the best advice you could want in it. I'd also recommend checking out Reaper which is comparable to Reason, Cubase or Protools. If this helps please let me know.
