Fisher and Paykel Aquasmart wl80t65c Logo
Misty higgins Posted on Apr 20, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fisher paykel aquasmart fault 49
Greg Stephen
Level 2:
  • Fisher and P... Expert 566 Answers
  • Posted on Dec 19, 2013
Greg Stephen
Level 2:
Answers
566
Questions
Helped
224497
Points
688
Fault code 49 is water valves, But the Aqua-Smart board is outputting the wrong code here, The Smart pump has blown the water valves fuse, A common thing in Aqua-Smart Machines.
The Smart pump has jammed with lint and caused over current to the board and taken out parts on the board that drive the pump.
Best to get a new/recondition board for your machine.
3 Related Answers
Anonymous
  • 30 Answers
  • Posted on Dec 02, 2009
SOURCE: i have trouble with my fisher and paykel washing
49. Cold Valve or Cold Valve & Hot Valve Faulty.
Testimonial: "thank you so much. now i understand what fault 49 is all about. however, can you help me fix the problem?"
luisa_sgro
  • 713 Answers
  • Posted on Apr 08, 2010
SOURCE: I put a small Carpet piece in my Fisher and Paykel
could b faulty control module. when pump jams or seizes on these machines it usually causes a fault in control module.whenever i found a control module faulty i always checked the pump for cause of fault.
Anonymous
  • 10 Answers
  • Posted on Jul 11, 2010
SOURCE: fault 49 smartdrive
Hi have had this problem on phase 5 grey controller, on the controll board near where the valve hot and cold wires are connected you will see a small usually blue resistor value approx 5ohms this is probably open circuit replace it check your water valves before reconnecting I was fortunate enough to have plenty of spare valves so I just replaced both valves as I suspect a faulty one may have damaged resistor machine has been working fine for some time since
Fault 49
The main board is displaying the wrong error
for the problem your machine has.
Fault 49 is water valves error.
The most common problem with AquaSmart is pump faulty
and damaged your motor control board,
Pump and motor control board need replacing.
Error 27 Fisher and Paykel
27. (00011011) Fabric Softener Valve Fault
The Motor Control Module has measured a voltage from the valve diagnostic circuit that
indicates the fabric softener valve (with Yellow Clip) is faulty. The most likely cause is that
the valve harness has not been connected correctly or the valve is open circuit. See fault
code 49 for service procedure.
Need a service, fault 49 ???????
cold valve fault. check the water supply, check the valves. otherwise it's the motor controller. replace parts as necessary.
1helpful
Fisher paykel aqua smart fault 49
TO FIX CODE 49 AQUASMART WASHINGMACHINE FISHERNPAYKEL
Yes you are right the pump in AquaSmart machines blows the water valves fuse that give you fault code 49.
I put a small Carpet piece in my Fisher and Paykel Aquasmart WL80T65CW top loading washing machine. It disintergrated and the machine stopped displaying "I need service Fault 49" I have removed and...
27helpful
2answers
Fisher@paykel aquasmart WL80T65CW1 fault code245 and code49
hi my fisher & paykel aquasmart has a message saying fault 49 what does this mean?
Top Fisher and Paykel Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
