ES-335 came with hard case with GIBSON Custom label
Your Gibson ES 335 was made at the Nashville Plant, TN, USA at july 7th, 2001. Production number: 374.
As I already did, you can check your serial number here:
http://www.guitardaterproject.org/gibson.aspx
Regards
SOURCE: I need documentation to set
Intonation is easy if you have an electronic tuner, and instructions for a Les Paul style guitar will be close enough. Same with neck adjustment, if it is a set neck, use the Les Paul info. If a bolt on neck, everything but the neck angle is still relevant.
My bad! It is an ES 135 and all specs are correct and aligned with this Guitar. Sorry for the problem error
