Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
Posted on Mar 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whirlpool imperial series 2 ultimate care washer
Hello, I have a problem with this washer. It is currently leaking water from the front on the left when in use. I can see where the water is comng out of the middle, it looks like a hole in front of this 10in diameter little drum like object. Also, I can feel where the hole is, what do I do. Could this be a pump or possibly is it stopped up?
  • tarik916 Mar 11, 2009
    Thank you very much, is this something I can do on my own? Do you know where I could purchase one other than spending tons of money on a repair guy, don't get me wrong they have to eat too.
Anonymous
Level 3:
  • Whirlpool Master 3,361 Answers
  • Posted on Mar 11, 2009
Anonymous
Whirlpool Master
Level 3:
Answers
3361
Questions
Helped
1028982
Points
10654
Your water pump is leaking.
Replace it.
  • Anonymous Mar 12, 2009
    You can do it.
    Any appliance parts store sells them.
3helpful
Whirlpool ultimate 2 model#lsw9750pw3 ser.ct1941128 leaking in front. appears to leak from a bow with 2 hose connected.
Your water pump is attached to the motor and is probably the source of your water leak.
Replace the pump.
Use the attached video to show how to access the cabinet and pump.
4helpful
Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Whirlpool Ultimate Care 2 leak after wash cycle
Hello, you may have a small drip from the pump or a small drip from the hose that goes from the pump to the rear of the cabinet. To make sure you will have to run the unit with the cabinet removed. A local service tech can remove the cabinet quicklyand isolate the leak.
Water leak
remove the 2 screws holding the console in, they may have trim on them.flip it up and you will see 2 metal brackets on left and right. pop thos off taking note how they are on there, disconnect connector on the top of the cabinet(door switch wires)lean cabinet foward pull towards you.it is know free of the rest of the machine. put back reverse of these directions making sure the back lines up properly with the cabinet.
Whirlpool Ultimate Care II - Whinning and leaking small amount of water
If the water is appearing in the front of the washer, you may have a leak in the drain pump. The link I'm posting below gives step-by-step instructions on how to replace the drain pump.
http://www.fixya.com/support/r397092-replacing_water_pump
If it is not the drain pump, at least this gives you the necessary instruction on how to access the cabinet interior to inspect it properly. A whining noise could be something caught in the pump, or something stuck between the wash tub and outer basket. In order to run the washer with the case removed, you will need to by-pass the lid switch. this accomplished by jumpering the two BLACK wires on the lid switch connector at the timer. CAUTION: Unplug the washer before connecting the jumper wires. Then, plug back in and start the washer. Fill on the lowest setting and look for leaks.
NOTE: The drain pump is not serviceable and must be replaced if leaking.
I hope this helps you. Let me know if you have further questions.
Whirlpool Imperial
With the machine off and empty, fill the softner bin with water only. Does the water level go down or stay the same.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
