Heres the illustrated parts diagram showing the beakdown on the handle and location of the trigger mechanism. If you want the full parts manual, i can send it to you. :)
Can you send me a complete parts manual for The Stihl FS38
Hi! do you've an updated version (if exists) of the 2015 version of the STIHL FS38?, I see that the one you shared is for 2004 model (or the parts manual date). I'd appreciate if you can confirm an share if there is a newer parts manual for it. Regards!
Hi plink-plonk, can you send to me the STIHL FS38 full parts manual to rreexx(at)gmail.com???. Thank you in advance, I really need it. Regards from Argentina
SOURCE: Replacing trimmer line with blade for stihl fs 90r trimmer
If you bought the trimmer new there should be a rod about 6" long and 1/8" thick. Above the trimmer head below the trimmer gearbox there is a hole. You have to put the rod in that hole and turn the head until that locks it from turning.
From there you can screw the trimmer head off by hand, or a strap wrench if it's really tight. It may be left hand threads.
SOURCE: Need Stihl FS55 parts diagram. Thanks!
Standard carb settings for stihl equipment: screw both needles in, then turn anit-clockwise L- 1 full turn H-3/4 of a turn.
