Note: The S-Video cables are not compatible with the redesigned Super Nintendo. They are sold separately at most retail locations as well as nintendo's Online Store.
Installation Steps: Locate the Audio/Video inputs on the back of the TV or VCR. Place the black end of the S-Video Cable into the S-Video IN on the back of the TV or VCR. Connect the red end of the cable to Audio IN Right.Connect the white end of the cable to the Audio IN Left. Use a slight twistingmotion when inserting the each cable and ensure the cables are firmly pressed into the input. Connect the rectangular (gray) plug of the S-Video cable into the multi-out connector on the back of the Control Deck. After system is connected to the TV or VCR: Insert Game Pak fully into the Control Deck. Plug the controller(s) into the front of the Control Deck using the left-most port for one-player games. Plug the AC Adapter into the back of the Control Deck. Plug the other end into a wall outlet. Set the VCR's TV/VCR button to VCR. You can put a movie in the VCR, press Play, make sure the movie appears on your TV, then press Stop. This puts your VCR into VCR mode. Slide the Power Switch on (toward the Game Pak). Turn on the VCR and locate the input select. It's often called: input select, AUX auxiliary), Line, Line In, Input, Source, Select, In, or EXT (external). Switch the input select to show the Nintendo game. The game image should now be displayed on the screen. You're ready to play! To record video games, set the system up to play games as usual, then insert a video tape and press Record. It's that easy!
Connect you vcr audio video output to tv audio video input and turn it on. On your tv menu select video input. If you see 'tv\video' on the button switch of the remote control or tv switching panel, press it.
Samsung BD P-3600 Blu-Ray is 6 months old and won't play bonus features as of a month ago. I hear a few seconds of audio with black screen, then it jumps to player menu and won't do anything else until I turn it off and back on. Update is current.
If even the sound aside from the video is not reproduced on the TV, then your description "connect" indicates that the TV is not set to receive the audio/video signals from the VCR. Initially, pls try:
set the TV to Channel 3 (or 4); or
set the TV to A/V, Video 1 or Aux 1.
Additionally, you need to confirm how the VCR is hooked to the TV unit, bu a single coaxial cable or 3 cables with RCA connectors (yellow, red & white).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.Good luck and kind regards. Thank you for using FixYa.
problem: during tv mode the reception will loss and back
in turn to blue color then back to channel frequency!
at video the picture is okay but ther is no audio!
can you please suggest me how to solve this problem
can you send this to my email add.
albertdlc_12yahoo.com thank you and more power!
The tv has a set of imputs for audio and video ,there is a posibility your dvd is not working right,you can also try a vcr by using the rca audio and video outputs of the vcr to the rca audio and video imputs of the tv,that will tell you if the dvd is not working ,the tv should have a switch selector for video and antena or have a channel below 1 called aux.
* The MPEG Playback function works in M. PLAY mode only.
* You can play moving picture images on the Memory Card.
* To hear sound during MPEG4 playback, you must hook up to a PC and listen to the PC's speaker. (You cannot hear it from the speaker on the camcorder or a TV)
1. Set the mode switch to MEMORY CARD position.
2. Set the power switch to PLAYER mode.
3. Press the MENU button and turn the MENU DIAL to highlight MEMORY.
4. Press the ENTER button to enter sub-menu.
5. Use the MENU DIAL to select MPEG4 from the sub-menu. (M. PLAY SELECT)
6. To exit the menu, push the MENU button.
7. Using the (FWD) and (REV) buttons, search for the moving picture that you want to playback.
8. Press the PLAY/STILL button.
The moving pictures recorded on the MEMORY CARD begin playing back.
