1994 Chevrolet Caprice Classic Logo
Jan M. Brady Posted on Jan 15, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have a 94 Chevy caprice classic L's and it seems as if wen I would try to start it will crank up but u could hear it firing back on one side of the right muffler(dual mufflers)n when I tried to st
James Arnold
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 67 Answers
  • Posted on Jan 15, 2018
James Arnold
Expert
Level 2:
New Friend:
Cheetah:
Answers
67
Questions
Helped
43130
Points
187
Sounds like dampness. Remove plugs, use a hair dryer to dry all funnels and wire connections.
5 Related Answers
Anonymous
  • Posted on Nov 18, 2008
SOURCE: 1995 chevy caprice classic
Try replacing your fuel pump relay, Its common on chevys.Those fuel pumps are too expensive to keep replacing
s60six
  • 328 Answers
  • Posted on Dec 31, 2008
SOURCE: Chevy Caprice , Power Steering
low power steering fluid
worn out steering box
bad power steering pump
Anonymous
  • 206 Answers
  • Posted on Mar 24, 2009
SOURCE: my 1994 chevy caprice classic wont start
Put the key in turn it on don't start it wait 10mins turn the key off remove it waits 10 seconds repeat this 3 times this should help if not try this with another key if it still don't work your ignition switch ifs probably bad dealer must replace and reprogram new keys. I got this info from the emission wiz it helped me on 2 different cars
Anonymous
  • 1118 Answers
  • Posted on Mar 28, 2009
SOURCE: transmission leak 94 caprice classic
If its in the line its self just cut the line in two and take some fuel line hose, the right diameter, slip it over the line with a couple of clamps and that should fix it. Theres not much pressure there and its a cheap fix.
ourhowse
Dar
  • 2007 Answers
  • Posted on May 13, 2009
SOURCE: my 1995 chevy caprice ignition coil has no fire
Change coil pack.
2answers
Why does my caprice start and shut off?
have a 1994 caprice that is not fireing can u help
How to install vacuume lines on a 94' chevy caprice
Vacuum hose is sold at many store in rolls, you would measure how much you need and replace the pieces one at a time, so as not to get them confused.
They also come in many sizes, so you should take the a sample of each size you find to get the right replacement.
Be blessed.
I have a 94 caprice lt1 5.7 I brought a brand new battery for it and when I turn it over it don't say nun at all no lights or nothing come on but da battery has juice
I dont know which model you have. My sons 94 caprice classic fully loaded he got used at an auction. Didnt know it at the time but it was one a cop car. Look on the front of engine under the crank case there should be something called an optispark on it. It has four wires coming out of either side and they run back to your plugs. Thats what was happening to my sons
1995 chevy caprice classic wiring for crank sinsor
Yup! I just bet you ARE having problems trying to locate the wiring for the crank sensor.
1995 Chevrolet Caprice Classic is only equipped with one of two engines:
4.3L (VIN Code "W")
5.3L (VIN Code "P"
Niether
of these engines were equipped with a crankshaft position sensor.
94 caprice won't start after it rains have to crank over many times starts great during dry weather restarts in wet weather after initial hard start 4.3 V-8 I'm thinking distributor
94-95 B Bodies have a On Board Diagnostic Built in the AC System! Try holding the AC "OFF" and "TEMP^" buttons at the same time until the screen looks funny with all the lights on! the scroll with the temp up and down button till u see 00 and hit the button that says "MIDDLE" to enter! If done right, i will start displaying any stored dtc codes. tehn let me know what code it shows!
3helpful
What is the 94 Chevy Caprice Classic wiper arm
heres a wiper linkage asm diagram, the wiper washers are on the hood or on the cover to deck,then the hose runs through the wiper arm to a nozzle, if you remove the arms you can lift cover enough to look at the hose to washer connection,also check hose to arm they often break there good luck.2d8c418.gif
2helpful
2answers
Car won't start, wait 15 min. will start but kinda backfires.
possible ignition coil pack breaking down...unit cools off them fires plugs again...fuel pressure is a concern also ..possible failing fuel pump
Faulty cigarette outlet on 94 chevy caprice
Have a look under dash on drivers side for fuse panel, and you may have some under the hood, near battery, but i expect it will be in the interior fuse panel.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
