Drain valve should be located on bottom of water heater.
http://waterheatertimer.org/Water-heater-will-not-drain.html
http://waterheatertimer.org/images/Marathon-drain-valve-2.jpg
http://waterheatertimer.org/How-to-replace-water-heater-drain-valve.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: dripping from drain spout
If you are refering to the "Dripping coming from the preasure tempature valve,Then just turn off the valve where the water goes into the heater and open the P/T valve with a bucket below it draining only emought water to get below the level where it reaches. Normally the drain valves are plastic with a Male hosebib attached. Attach a garden hose to the rain and run it out to a point lower that the vaslve in order for gravity to drain the tank.The valve opens counter clock wise. If the valve is stuck or does not drain,and you have a foor drain handy,remove the whole valve and replace it with a boiler drain valve. If The tank is located below the drain level then you will have to either pump or carry the drain water to the higher level. Replace the P/T valve and reinstall the associated associated piping. I would use tefelon tape on the P/T pipe theads. You may have to open a hot water faucet in order for the air to replace the water in the tank ,in order to drain.
SOURCE: Dripping Drain valve on rheem water heater
If your water heater is 10 years old or more, it's much better to replace the entire thing before you start having additional problems with it. You MAY be able to drain your water heater and replace the valve with something more reliable, but, as I've said... if your water heater is old, this is just the 1st thing to go wrong. More will follow.
SOURCE: I have a Rheem glas fury model 22-40 gas water - leaking
once they leak it's time for a new water heater. ther is no way to repair a tank leak
SOURCE: Rheem water heater turns off by its self
Flashing code 76 is lost communication between the remote and the burner control assembly CCA (circuit card assembly). The CCA is still under warranty if purchased within the last 3 yrs. Contact Rheem customer service and have your Mod. and S/N available....explain to the agent you are recieving - flashing code 76...they'll walk you through the process.
SOURCE: water dripping out of drain line
The T & P valve is connected to the drain and it may be bad causing it to drip. You could try lifting the lever and then closing it back on it to see if it will seal. Also check the thermostat for heat setting, but than likely it is going bad.
It is a pressure relief valve and normally last about 5 years or more before they need to be replaced. The purpose of this valve is to protect heater from building up pressure and protecting the home, It releases water once the heater reachs beyond the limit of the valve can handle.
It is a standard 3/4" thread and can be removed with a pipe wrench. Just turn power, water off and drain water down to just below where the drain is.
Lowes or Home depot shoul dhave one just ask for a pressure relief vakve for a Hot Water Heater. prices range around $15.00.
Testimonial: "The response you forwarded to me was not the problemm. I simply had to drain tank down and replace plastic drain valve to a brass one. Plastic Drain Valves are prone to leaking"
