Recently, when I wash the same kinds of loads I've always washed, my LG frontloader doesn't know when to stop. It'll say, for example, that there are 34 minutes left in the cycle, but an hour later, it's still spinning and never quite entering the high-speed final spin. A couple of weeks ago, I had an "unbalanced load" error, but it went away and i don't know if that's related or not.
SOURCE: LG front load washer/ clothes still wet after final spin
The heavy jacket prevented the washer from spinning at a rapid pace, so I added a heavy bathrobe to absorb some of the water and to balance the load. The washer then spun very quickly and drained out all the water.
SOURCE: LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
SOURCE: LG WM0642H washer "excessive" vibration
sounds like damper rods are getting worn. they support bowl underneath.i think if u change them it should fix problem. is it noisy during spin?if u need more help please reply. please turn power off b4 working on it do not want any accidents.
SOURCE: I have an LG front loader, gets stuck on spin cycle at 9 min
The timer is likely failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: 1 1/2 year old lg WM2496H showed oe error code
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!!!!!!!!!!!!
Problems
with a washing machine not spinning or not draining are often inter
related..
If you are having a problem with your top load
washer then check out this tip...
Washing
Machine
does not Pump or Spin
If you are having problems with your
front load washing machine then checkout this tip...
Front
Load Washing
machine not draining and or not spinning
heatman101
