Haier HTQ21JAAWW Top Freezer Refrigerator Logo
Kathy Plomp Posted on Aug 04, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fridge won't quit running and get cold
I have a 2 year old Haier fridge model #HTP18GAA and I also am having the problem with my fridge running all the time and not getting cold,my power bill is going up and my patience are running out. I paid good money for this product and can't afford to replace it
Anonymous
Level 2:
Novelist:
  • Expert 159 Answers
  • Posted on Aug 04, 2007
Anonymous
Expert
Level 2:
Novelist:
Answers
159
Questions
0
Helped
172185
Points
274
2 common problems that unit has. 1 is the cold controls go bad and will cause the unit to either run or not run. 2 the freezer drain gets blocked up very easy and when the freezer defrost the water has noplace to go but the freezer bottom and could block the air passages so the cold air will not satisfy the control. so check the freezer bottom by removing the plastic peice on the bottom there are 3 plastic plugs in the front that secure it and some phillips screw in the middle. you can just lift it to check for ice. if there is none replace the cold control. good luck
Htp18gaa fridge control board location
Your model does not have a control board all control components are found in the control panel
Control Panel RF 7350 58
APPLIANCE 911
Mini fridge not getting cold,freezer only gets cold?
If it's less then a year old you have a warranty, if it's older you are better off replacing the unit as direct parts are not available and subs would cost more that the unit.
The bottom part of the refrigerator does not cool at all
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Fridge won't get cold
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Fridge not cold but freezer working great
I had the same problem, and it turned out to be a cooked fan motor.
I couldn't find a reasonable (less than $150) replacement motor from Haier places, but I just took the motor out and took it to an appliance repair center (in North Denver)
They said it was a standard part, charged me around $22 for a new one and I was all set.
For my replacement motor, it was a reversible design, and was initially set to go the wrong way, so I had to reverse it.
3helpful
Fridge heller model fdh21has motor running but does not get cold
i have just purchased a float with a kitchen in it the fridge is a heller bar fridge not sure on model and for the 2nd use it is running but not getting cold or icing up the freezer what do i do to fix it it wouldnt be 10 weeks old
Clicking near compressor but doesnt run not even a year old haier compact mini fridge
since your mini fridge is under warranty, have a technician come and take a look at it. i would say it's the damper.
1helpful
Haier HVT 12ABS fan runs, but fridge does not get cool
Hello warmfridge
happy to assist you,
You said,
We've had this wine fridge for about 3 years now, and all of a sudden it stopped getting cold. We still hear the fan turn on and all appears to be running smoothly but it remains room temperature inside. Does anyone know how to fix this? I have no experience, but would like to try rather than buy a new one. thanks!
1. You may need to add freon.
2. It may have a faulty thermostat.
It seems you need hands on service!
Our site has good companies in the repair directory.
Bless you,
please rat me here before you sign off.
Thank You
Indesit fridge freezer (2 years old) not getting cold
if compressor is running, then you are correct in saying no point in replacing stat. by sounds of it you have a faulty compressor fault or a syatem fault - impossible to dignose by remotely. this is not a diy job i'm afraid
Top Haier Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
vince
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
