Question about Dell Photo 964 All-In-One InkJet Printer
How to get the all in one fax / copier /printer to stop printing a report after each incoming and out going fax. It waistes ink and paper.
  • epochframewo Mar 12, 2009
    Thanks so much!!! My ink cartridges and paper supplies will last longer!!!
  • 903 Answers
1 Click Start Programs or All ProgramsDell PrintersDell Photo AIO Printer
964
Dell All-In-One Center.
2 From the Dell All-In-One Center, click the Maintain/Troubleshoot tab, and then click
Display the Printer Setup Utility.
Printer Setup Utility Tabs
On this tab: You can:
Send • Enter your name and fax number.
• Select a maximum send speed and a print quality for outgoing faxes.
• Choose whether to scan the entire document before dialing the number.
• Choose whether to use error correction.
• Select when to print a fax usage report.
• Select when to print a fax activity report.
this information is from the manual found here
http://support.dell.com/support/edocs/systems/PRN964/en/om/om_en.pdf
I hope this helps
Posted on Mar 12, 2009
  • Debs
    Debs Mar 12, 2009
    you are very welcome
  • JIm DiGiovanni Jan 22, 2013
    can't connect to PC running windows7 to utilize this option & didn't see any way to do this from printer front panel - is there?
6ya staff
SOURCE:
Fax confirmation
most printer in the market has the same standard setting for the fax.
u can set the report many types for many user's purposes, some people want to save paper, save ink/toner, so they dont need report if the fax is sent but only print report if the fax is not good(NG or not sent)
it can be set to:
report off--means report will be print out only if the fax is NG
report off+image--means report will be print out if the fax is NG + the image of the page that is not sent(so we know which page is not sent through the image)
report on+image-- every fax activities( sent or not sent) will be reported, which is not recommended
etc....
how to set is depends on your printer, just go to the menu "FAX" and look inside the menu.
Jul 08, 2014 | Epson Workforce 520 All-in-One Color...
MX-310 has fax's in memeory but keeps printing the first page of the first fax only. Screen says check paper size. When i push ok it only will print the first page over and over. How do I change it?
If your Canon MX-310 has been set up to print faxes as they are received, then what is actually in memory is a "received fax report". If you select a particular fax in this report, it will print the first page of the fax to remind you of the content.
Your Canon MX-310 will store fax documents in memory if:
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
Dec 04, 2009 | Canon PIXMA MX310 All-In-One Printer
On my Canon MX310, the display says "Waiting for Report". Fax Memory is clear, but the In Use/Memory light stays on.
Try this step ... found it on Canon's website
Issue: ERROR LCD: WAITING FOR REPORT
Solution: Set [AUTO PRINT RX] to ON (MX300 / MX310)
AUTO PRINT RX When [AUTO PRINT RX] is set to [OFF], incoming received faxes will be temporarily stored to memory and transaction reports (TX, RX and Activity) remain in memory. The default setting is [ON], which means incoming received faxes and transaction reports will automatically print. The fax machine will not automatically print a received fax and will store it in memory in the following conditions.
  • Paper has run out
To set AUTO PRINT to ON, please follow these steps.
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button. [FAX SETTINGS] is displayed
  3. Press the left or right arrow button to select [RX SETTINGS] , then press <OK> two times.
  4. Press the left arrow to select [ON], then press <OK>.
    Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK.
  5. At sub-menu PRINT WHEN NO INK, decide if you'd like the machine to continue to print incoming received faxes if ink is low.
    CAUTION: When this option is set ON, the fax machine will not monitor the ink level of the ink cartridges. If ink is low or out, received faxes will print with streaks or blank. Furthermore, once the fax is printed, it will be deleted from memory.
    1. To print received faxes when ink is low or out, press the left or right arrow to select [ON] and then press <OK>.
    2. To store received faxes in memory when ink is low or out, press the left or right arrow to select [OFF] and then press <OK>.
  6. Press the <Stop/Reset> repeatedly to return to Fax standby mode.
Nov 17, 2009 | Canon PIXMA MX310 All-In-One Printer
How can i generate incoming call report ?
To print a report:
  1. Press the [Menu] button on the Control Panel, until Reports is displayed on the top line of the Display Screen. The Phone Book menu item will be displayed on the bottom line.
  2. Press the right or left arrow button to scroll until the report or list you want to print is displayed on the bottom line.
    • Phone Book: Phonebook list
    • Sent Report: Sent fax report
    • RCV Report: Received fax report
    • System Data: System data list
    • Scheduled Jobs: Scheduled job information
    • MSG Confirm: Message confirmation
    • Junk Fax List: Junk fax number list
  3. Press [Enter] to print the selected information.
Your machine can print reports containing useful information. The following reports are available:
  • Phonebook List: This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers. You can print this phonebook list using the [Phonebook] button.
  • Sent Fax Repor: This report shows information of the faxes you recently sent.
  • Received Fax Report: This report shows information of the faxes you recently received.
  • System Data List: This list shows the status of the user-selectable options. You may print this list to confirm your changes after changing any settings.
  • Scheduled Job Information: This list shows the document currently stored for Delayed faxes or Toll Save faxes. The list shows the starting time and type of operation.
  • Message Confirmation: This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job.
  • Junk Fax Number List: This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID.
  • Multi-Communication Report: This report is printed automatically after sending documents from more than one location.
  • Power Failure Report: This report is printed out automatically when power is restored after a power failure, if any data loss occurs due to the power failure.
NOTE: The lists you have set to automatically print out will not print out when there is no paper loaded or a paper jam has occurred.
Aug 04, 2009 | Xerox PE120i Laser Printer
Empty incoming faxes
Check to make sure the ink is coming out of the cartridge as this often takes some coaxing with a new one. Take the cartridge out of the printer and dab the print head on a piece of paper and check to see if the print head leaves a mark on the paper. If you see 2 stripes on your paper it means the cartridge is okay. On the other hand, if there is no ink mark left on the paper it means that the ink is not flowing freely from the print head. In this case, fill a saucer or old coffee mug with hot water and place the cartridge in the water so that only the print head is submerged. Leave it for a few minutes and then dab it on the paper again to see if the ink is flowing.
Please let me know if this is not what's causing the problem.
Best wishes,
Graemevm
Apr 30, 2009 | HP Officejet 5510 All-In-One Thermal...
How do I stop daily reports from printing? How do I change the default tray for fax reports?
To program a default paper tray to print fax reports, perform the following:
1. Select Utility/Counter.
2. Select User Setting.
3. Select System Setting
4. Select Paper Tray Setting.
5. Select Print Lists
6. Select the paper tray for the fax reports to print from.
7. Press OK.
8. Press Exit on the lower left side of the display to return to the copier screen.
to set the activity report to not print daily
1 touch the utility button
2 touch administrator settings and enter the password 12345678
3 press fax setting
4 press report settings
5 select activity report and change to off
6 press close then exit
Mar 17, 2009 | Konica Minolta bizhub C250 All-In-One...
Machine refuses to print incoming fax. "Paper mismatch"
HP Printer 7210 or 7310 Gives Error receving faxes Load a new blank paper on paper tray.
Press * and # simultaneously, and then release both buttons.
Press 1 , 2 ,and then 3 . The Service menu appears.
Press the right arrow button (>) until the System Configuration menu appears then press OK.
Press > until Media Sense Calibration or Calibrate Spot Sensor appear and then press OK. The unit should pick the paper and eject it.
Press the Cancel button until date and hour appear on display
Mar 05, 2009 | HP Officejet 7210 All-In-One InkJet...
Lots of useless reports printed
You should get the Number of the Companies Fax Number and complain to your Telephone Provider, that your constantly receiving fax messages from a Company that's obviously dialing the wrong number.
The fact that they're not getting any replies from you surely should lead them to realize that they are dialing a wrong number.
Then perhaps the Telecoms Company can put a Block on the Number from calling you again.
Worth a Try :-).
Dec 05, 2008 | HP LaserJet 3050 All-In-One Printer
I don't want fax receiving confirmation report it waste my paper.
Go to menu (wrench)
Arrow down to Reports - OK
Arrow down to Fax Reports - Ok
Hit Ok at Fax Confirmation
Select Never and hit OK
Hit Cancel when done and it should now not print confirmations.
Dec 05, 2008 | HP LaserJet M1522nf Multifunction Printer...
Document in ADF error when faxing
  1. This problem is caused by refilling your ink cartridge but there is a solution
  2. When the ink is low or the computer thinks the ink is low the sheet feeder will not work
  3. You will notice that the in use/memory light is on
  4. The memory has a report it needs to print but does not want to print it without ink
  5. To print the report anyway do the following:
  6. Press the <FAX> button to enter the Fax menu.
  7. Press the <Menu> button. [FAX SETTINGS] is displayed
  8. Press the left or right arrow button to select [RX SETTINGS] , then press <OK> two times.
  9. Press the left arrow to select [ON], then press <OK>.
    Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK. Select Yes. make sure there is paper in the printer.
  10. At sub-menu PRINT WHEN NO INK, decide if you'd like the machine to continue to print incoming received faxes if ink is low.
Aug 25, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Dell Photo 964 All-In-One InkJet Printer Logo
137 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
