At the time of start up it shows " your pc needs to be repaired error code: 0xc0000185
This error can occur when there is a problem in reading and/or verifying data on the HDD/SDD. The most common cause is a loose data connection, although the power connection can cause similar issues. Check the connections at both ends of the cables. Also check the connections to your optical drive and make sure that your RAM is correctly seated. Since you have already opened your laptop to do prior maintenance, it is quite possible that you have dislodged one or more cables without realising it. By the sounds of it, your laptop continued to work for a short while before failing again with your current issue. It is likely that a sudden sharp knock might have caused a loose connection to become disconnected.
Steps To Troubleshoot Acer Error 0xc0000185:-
Solution 1: Repair the Computer by Windows Installation Media
The very advances is to embed your Windows 8 or 8.1 Installation DVD or USB or even recuperation circle.
Presently, try to boot from the plate to get to the setup screen
In the Windows Setup screen, you have to tap the "Following" catch
Snap the "fix your PC" symbol
Presently in the "Propelled Startup alternatives", simply tap the "Investigate" symbol
Snap on the "Propelled" alternatives and pick the "Programmed Repair" symbol
Check for every one of the "Associations Of Your Computer's Hard Drive" cautiously.
As we realize that this blunder code happens because of a free wire embedded into the hard drive. So getting to the hard drive and reconnecting the wires physically will fathom the issue
Solution 2: Running the ChkDsk Command
Press the "Windows Key+X" symbol and afterward click the 'Order Prompt "symbol which will be your Admin
In the Command Prompt window, clients are required to type the "chkdsk/R >" content and press the 'Enter' symbol.
For more information or help visit link below :-
https://www.acersupport247.com/blog/fix-acer-error-0xc0000185
