Intel core tm duo cpu e4500 motherboard
Intel = Processor (CPU ) manufacturer
Intel Core tm = Trademark. The Intel Core is a Trademark from Intel
CPU stands for Central Processing Unit. Another term used is Microprocessor, or simply - Processor for short.
e4500 is an Intel Core2 Duo processor.
Maximum frequency rate ('Speed') is 2.2GigaHertz.
2MegaByte of L2 Cache. (2MB of L2 Cache)
800MegaHertz Front Side Bus. (800MHz FSB)
Tells me Nothing about the actual motherboard. Look on the motherboard for a Model Number. May be in center of motherboard. May be on edge of motherboard. May be in-between one of the expansion slots, on motherboard.
Post back in a Comment.
Also post what the problem is, in your best description.
Computer does not turn on. (Power Supply does not turn on)
Computer seems to turn on, but get No Signal on monitor, or Sleep Mode on monitor, or Power Saver Mode on monitor.
LED lights light up, and fans spin.
Regards,
joecoolvette
SOURCE: i need mother bord cd for Intel(R)Core(TM)2 Duo CPU
The motherboard box may help. Or you may need to open up your case and see what model your motherboard is. Do a search for the model and see where it takes you. The motherboard site will usually carry drivers for what you need.
If you do find the appropriate software, I suggest copying the files to cd, or dvd and putting the disc in a safe place just in case you do format again.
SOURCE: I don't no my motherboard
Is Your product Branded or Non-Branded? However if it is Branded than you can find all the Drivers and Softwares on the official site of it Brand. For an example if you Brand of Intel you will go www.intel.com and will chose Support & Downloads and will ask you to input the data regarding your brand model there you will type in like for example GF 8800 and there it will give you all drivers available free of coast.
