Put about 30L in tank ran about 2 min. then quit tried to start,what has to be replaced. Or will draining the tank and flushing the system work?
I would recommend draining the tank, replacing the fuel filter, you will probably have to replace the spark pugs as well. You may want to also blow out the fuel lines if easily accessible. Put in new gasoline, a fuel system additive, and run it for a little bit (may get some smoke for a bit, and my be hard to start at first and run rough). Hope this helps.
