I have the kenmore he2 front loader and was wondering if the water comming in to do the load is enough. I realize that it is way less than a top loading washer but my husband is getting a rash(he has very sensetive skin) and we have switched to the all he for sensitive skin even and only use a small amount. When you look in the washer every thing seems wet but there really is not alot of extra water. I really have never had a front loader before and don't know what is normal and what is not. help please.
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
I would not be so quick to judge it as a clog. Check valves often take the shape of a ball. In transmission and carburetors they are steel. Given that the he2 drum is lower then the drain connection in the wall it makes perfect sense for a check valve in the drain hose. If you can not see a way for it to get in there and it appears large enough to stop water form flowing back into the machine I am betting it is a check valve. Look carefully at how it might fit on the machine side of the line, if I am right, it should be able to block the hole. When water is moved toward the house drain, there should be no way for it to block the water. There is also a very good chance it is a solid ball. Look at it very carefully before deciding to remove it.
