Posted on Mar 13, 2009
Do not know how to turn off alarm setting for clock radio
RCA clock Radio model # RP3720A
Anonymous
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Feb 21, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
14394
Points
22
Instructions are here: the closest available RCA CD-CLOCK RADIO USER MANUAL online is for Model #RP5610 at this location: http://www.voxxsupport.com/images/manuals/RP5610/media/RP5610_DOC_OM.PDF
If unable to link to that webpage, go to RCA Tech Support page at: http://support.rcaaudiovideo.com/manual.aspx?product=143 and click on download manual.
1helpful
Snooze set to 1 minute
First, move the slide switch at the left rear of the top of the unit all the way to the right. You'll see the colon blinking, indicating that you are in 'set' mode. Now turn the dial that surrounds the ON/OFF button on the top of the unit. You can move it clockwise or counterclockwise, to change the time forward or backward. When done, move the slide switch back to the far left. Done.
How to set and use alarms on RCA clock radio model RC46-A
Closest available RCA CD-CLOCK RADIO USER MANUAL online is for Model #RP5610 at this location: http://www.voxxsupport.com/images/manuals/RP5610/media/RP5610_DOC_OM.PDF
If unable to link to that webpage, go to RCA Tech Support page at: http://support.rcaaudiovideo.com/manual.aspx?product=143 and click on "download manual".
9helpful
2answers
I need an instruction manual for my RCA Clock Radio Model RP3750A. Can't turn off the alarm - want radio to come on with the radio and not the alarm.
There are three buttons under the heading "Dual Wake", WK1, Cancel, WK2. The WK buttons refer to the two wake time settings you can have. Press Cancel and then WKx. That will turn off the alarm. If you press WKx more than once, it will cycle through small symbols on the bottom of the screen with the number x in front of them. First symbol means it will have a sound alarm for alarm x, second symbol means it will have a radio alarm and the third symbol means it will play the CD to alarm. You set the time for alarm with the slide switch at the back of the unit, selecting WK1 for alarm 1 and WK2 for alarm 2. You can have both alarms active at once, or either one singly.
4helpful
Cant turn off alarm on RCA alarm clock model 3715A
It is almost exactly the same model as the #3700 series.
7helpful
3answers
Cannot turn off the alarm on my RCA clock radio rp5430
Look at the display. Look for a number 1 or a number 2 to determine which alarm is on. If you see a number 1, push the 1 button on the top right side of the alarm clock until the number light goes off (1 or 2 times, depending on whether it is set to beep or radio alarm). When the number is not lit up, the alarm is off.
Setting the alarm on my clock radio
use the selector switch on the top, switch it to wake 1 or wake 2. set the time that you want that alarm to go off. then push the switch all the way back to the left to deactivate it. then to activate the alarm, use the buttons on top labeled wake 1 or wake 2 to turn the desired alarm on. pushing that button repeatedly will cycle the alarm to either beep, radio, or it will turn that alarm off.
Mod. # RP3720A
Heh, great. I have the same problem. I LOVE this alarm clock, but I can never tell if it's 6:48 or 5:15. I've tried 4 different alarm clocks now and I keep going back to the one I can't read. I was trying to find an answer to what to do about it and came across this. Maybe there is no solution...
19helpful
2answers
How to set a RCA RP3720A model
74helpful
4answers
Changing time on RCA CD clock radio
UNPLUG!!! Wait 15 seconds. Plug in again, CLOCK will flash 12am.
Press "set" button ONCE.
Press Double Back Arrows |<< to go backward from Midnight
or
Press Double Forward Arrows |>> to go forward from Midnight
(Either press-hold the Double Arrows for quick minute-scroll or repeat-press Double Arrow for a slower minute-by-minute change.)
4helpful
RCA RP3721 Alarm won't shut off
To turn alarm off completely, press WAKE1 and WAKE2 until the bell-shaped indicators go off.
As for resetting the alarm (buzzer), press SET WAKE/CLOCK untill SET and WAKE! light.  Press left- or right+ arrow to set time.  Press WAKE1 until bell-shaped indicator comes on.
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
