Dryer runs but no heat to dry clothes
The machine is probably doing exactly what it is supposed to do and failing safe because of a problem. This problem is usually the result of an overheat causing a thermal cutout to trip. While I don't know this machine specifically, you will probably find that there is a screw on bulge on the back of the machine that covers the fan and heater unit. (Unplug from the mains first!!) remove the panel (Usually about 6-8 screws) and inside you will find a heater element. Near to this you will find at least one thermal cutout, it will be a little metal disc set in plastic, about the size of a penny with 2 wires coming off it. There may be more than one of these, but typically, only one has a tiny hole in the back at the centre. If you push a paper clip or pin into the hole gently, you will hear a click as the metal disc in the cutout pops from a concave to a convex shape and re-sets the cutout.
Reassemble and the problem should be fixed. Now ask yourself why it tripped? Usually because:
Both these things will cause an overheat and the cutout will trip.
These things very seldom fail because of a fault, but if the unit keeps tripping the thermal cutout, the problem may be a real heater fault and you should look to change the heater element or get someone to change it for you if you are unsure.
