My Frigidaire top load washer operates normally until near the end of the wash cycle. The water drains normally then the washer spins. At the point where it is supposed to start the rinse cycle... it stops and does nothing else. I have tryed to manually advance the control knob a few clicks to the middle of the rinse cycle, but it still does nothing. If I manually advance the control knob past the rinse cycle to the last spin cycle, it starts working again. So the problem is with the rinse cycle. I hope you have a few ideas. Thanks for your help.
Hello Dorothy - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
