HP LaserJet 1320 Printer Logo
Posted on Mar 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Laserjet 1320n Will not print
I recently changed computers (Win98 to another Win98), and the device will not print. Worked fine on the other pc
  • 1 more comment
  • smharris83 Mar 13, 2009
    I am using a USB cord. Same exact set up as my older computer. This is also an old computer but is running same version of Win98. I have installed the software & drivers and nothing... I can open the HP toolbox but under status it says "An error occured" : Make certain that the device's power cord etc., etc., is plugged in, which they are.
    Several drivers for the USB are installed...
    *USB Root Hub
    *VIA Tech 3038 PCI to USB Universal Host Controller
    *Dot4 HPZ12
    *Dot4Print HPZ12
    *Dot4Usb HPZ12
  • Anonymous May 11, 2010
    What type of cable are you using to make the connection? It may require a parallel cable rather than a USB, or vice-a-versa. You new computer, the one you switched to, may not recognize the cable.
Anonymous
Level 3:
  • Master 463 Answers
  • Posted on Mar 13, 2009
Anonymous
Master
Level 3:
Answers
463
Questions
0
Helped
247103
Points
1336
You need to install the 1320 driver on the "new" pc.
  • Anonymous Mar 13, 2009
    do you have the proper driver for the USB card/hub in the "newer" computer? Windows 98 most certainly did not have native USB support for ALL devices... Check the device manager....
HP LaserJet 1320n Printer connected with usb to pc running on windows7; faded printing; economode = off; printer Density =3; what could be the problem
Faded printing is usuallly caused by an empty or defective toner cartridge. If the toner is new and the printer was working fine before the toner change then you might have a defective cartridge, or you may not have removed the tape strip from the cartridge when you installed it.
4helpful
2answers
Is there a counter for pages printed on my 1320n
No, the page count is not on the test page. You need the configuration page. Press the GO button and hold for 5 seconds. The yellow light will come on and you can release.
I can't remember what side ink cartridge i need
You will need to purchase either the Q5949A or Q5949X for the LaserJet 1320.
The Q5949A will print approx. 2500 pages at a 5% page yield or
The Q5949X will print approx. 6000 pages at a 5% page yield.
Printer wont print after ink cartridge change
Hi pater_g:
Have you tried to reinstall the old cartidge to see if it would give a different problem ( light print ect.) if not try that. If the problem stays and you just can't communicate with the printer try rebooting you computer or go to www.hp.com/support to download a new print driver. I hope this helps you.
I was printing in hp laser jet 1320n.....it was all going fine..but suddenly the paper got stuck in the rollers, while pritning a job. the paper is still stuck and just doesn't budge. what to do to release...
first you open the back side door of the printer and put down the two green lever and take out paer from there easily if possible clean fussing unit also.
1320 not 1320n
These days printers are cheaper than before. Why spend money and buy with no warranty.
I would never buy a printer or a computer second hand (used one) unless it is free.
If you are a business person why mess with the used stuff.
ag
Light print out
plz try with new tonner
1helpful
2answers
HP Laser Jet 1320n series
The HP LaserJet 1320 has a USB port and a Parallel port.
The HP LaserJet 1320n has a USB port and an Ethernet port.
USB-to-Parallel converter cables, like this one, are designed to attach a parallel device to a computer's USB port.
But you need to do the opposite (attach a USB device to a computer's parallel port). A USB-to-Parallel converter cable will not do this.
2answers
Unable to communicate to a 1320n laserjet printer
unistall the driver completly and install again so after that click shared printer and them try it
1320n won't finish print job
This seems to be a Card failure- time for a replacement? is that possible?
k24674
Grand Canyon Tech
Grand Canyon Tech
