Panasonic Lumix DMC FZ47 also known as FZ48 Digital Cameras Logo
Anonymous Posted on Apr 26, 2013
Panasonic Manuals Can't force the flash to work...
Jim Thomson
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Master 1,099 Answers
  • Posted on Apr 28, 2013
Jim Thomson
Master
Level 3:
Renaissance:
Answers
1099
Questions
0
Helped
276079
Points
2710
I had a similar problem with my panasonic and it was because I had the camera set up to take multiple shots. If you put it on single shot it will allow you to use the flash at any time. Hope this helps.
How do I defeat the flash on a Panasonic DMC-TZ3?
In the Flash menu, there is an option for Forced Flash Off. Press the Flash button to the right of the Menu button. Then use the up down arrows to move to this option. (It's at the bottom of the list.) Then press Menu to set the option to the Flash Off. This is shown on page 36 of the manual for the DMC-TZ3. I found a copy of the manual here: http://panasonic.ae/en/manuals/DMC-TZ3.pdf .
Your pictures may have exposure or blurring issues in this mode. The shutter will stay open longer to attempt to gather enough light.
I hope this helps.
Flash not working on DMC fx33
Are you sure you enabled flash through the options? Check the user manual for any setting related to flash before considering having the camera serviced:
Panasonic DMC FX33 manual
The flash on my Panasonic DMC-FZ100 doesn't work, I've tried 'forced flash' and thats not working either?
Hello Ray, This is not something a user wants to attempt !!! The camera really needs to be repaired by a tech. You will do more harm than good by trying to fix it yourself and will cost even more if you damage something.
Best Regards, Russell
1helpful
Panasonic Lumix DMC-FP3 Flash option not showing
Is flash set to Force Off? (page 36 user guide)
Have you tried to reset the camera? (page 21 user guide)
Ref: http://service.us.panasonic.com/OPERMANPDF/DMCFP3.PDF
Need User Manual for Panasonic Viera TH-L37X10S Lcd tv
The manual for theTH-L37X10S is available from Panasonic here: http://www.panasonic.ae/EN/Manuals/TH-L37X10A.pdf . (Note it's the same manual even though the final letter is different.) If the above link doesn't work, start here: http://www.panasonic.ae/EN/Pages/TH-L37X10.aspx and click on the Manuals tab.
I hope this helps.
12helpful
How do i turn off my flash on my panasonic dmc-fh27?
Touch [MENU] to bring up the menu. Touch [REC] to enter the recording menu. Touch [FLASH] to enter the flash menu. To turn the flash off, select "Forced Flash: OFF" (lightning bolt in a circle with a slash through it).
The flash menu is described on page 66 of the advanced manual.
My sony cyber-shot DSC-H10 flash stopped working. The flash pops up like it is going to work, but does not flash. I can take pictures but with noflash. Can you help me?
You flash is in ' Flash forced OFF ' position.Press on the flash control button repeatedly until one of the four modes are selected.
1.Flash Auto - Flashes when there is insufficient light or backlight ( Default Setting )
2.Flash forced on
3.Slow synchro - The shutter speed is slow in a dark place to clearly shoot the background that is out of flash light.
4.Flash forced off - ( Your current mode ).The flash automatically pops up and strobes when using the flash.Close the flash by hand after use.
6helpful
3answers
Problem with Panasonic DMC-TZ5, can not take pictures with Flash.
My TZ5 has developed exactly the same problem. I took it to DK Audio Services at Horley,Surrey,RH8 9GA. who repair cameras for Panasonic and was told by the receptionist that although the camera works with the flash off at present it will eventually pack up altogether. She suggested that when I get the quote I phone Panasonic on 08705 3577 357 to try and get them to pay for the repair, it seems it is a known problem! My camera is just over a year old!!
Flash problems fix Panasonic DMC-TZ1
There is a Force Flash setting on this camera I believe. Force Flash means Always Flash(on). If this does not work, then flash is burned out I would guess.
The TZ1 has been replaced by the smaller, newer and nicer wide angle TZ3 and latest TZ5. Consider selling you defect TZ1 to a repair person on ebay, and buy you a good used, refurb, or new TZ3 or 5. Prices are very good, and your is worth about $25 to $30 with all accessories that came with it.
Flash not working
"Forced on" means the flash is forced. Try "Forced OFF". Note that there are several options and scenes when the flash is enabled by default.
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
