Question about Samsung S860 Digital Camera
Lens stuck Hi, the lens of my camera is stuck and won't open, all that happens is a green light flashes
  • Samsung Master
  • 4,738 Answers
Please see this link for troubleshooting steps for a stuck lens.
And here's a video summary of the steps.
Posted on May 02, 2013
Anonymous
SOURCE:
Dean Vallejo
SOURCE: Camera Wont Turn on
Is there anything that sounds like a "beeping" noise when it extends? A lot of times the focus motor gears are knocked out of place. This causes a lens error, even if the lens extends fine. The camera has the "external" zoom lens, and an internal focus lens. This can be only fixed with disassembly of the lens, if indeed this is the problem you're talking about.
Posted on Oct 30, 2007
hittin1
Mark Brockman
SOURCE: samsung s630 camera
okay.... Try this if lens is stuck out... look at the side profile of the lens... you should notice the it is not even.. the lens is probably stuck at a slight angle.. GENTLY force the lens to where it looks even... should fix the problem.... worked for me.
Posted on Feb 25, 2008
Anonymous
SOURCE: samsun s630 lens is stuck out, won't turn on
guessing it was dropped, have a side look at the lens, its probably not straight. pull it straight gently and try again
Posted on Apr 21, 2008
Anonymous
SOURCE: Samsung L730 stuck
I tried turning it on, removing the battery, replacing the battery, and turning it on. This didn't work. When I repeated this but also removed the memory card, it did work.
Posted on Dec 21, 2008
Anonymous
  • 48 Answers
SOURCE: Camera won't turn on
yes,they have and i bet its all becausu your using regular batteries,you have to use energizer litium batteries.try it.good luck.im a photo technician,and sold digital cameras for 3years as a lab supervisor.and i have the same camera too,its awesome.
Posted on Apr 14, 2009
Shutters on the lens won't fully open
Stuck automatic lens covers are fairly. But usually it's very easy to fix, without even opening the camera. See this link for troubleshooting steps for this problem.
Dec 14, 2012 | Kodak EasyShare C633 Digital Camera
Hi I slipped in the garage and dropped the camera when it was on==batteries came out and lens of course didn't fully retract. Put batteries back in and the green light comes on and beeps but won't...
Sorry about your moms camera Terry... but it sounds like it needs the lens replaced. If the lens is stuck out at an angle you can *SNAP* the inner lens section back into place if you're lucky, and it will work again like normal.
I don't know your model, but a refurb lens can usually be installed for about $75 including return shipping. You should check the replacement cost of a used camera and see which is cheaper in the long run.
Hope this helps!
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
Jul 25, 2011 | Samsung Cameras
LENS OPENING BUT NOT SHUTTING
Its seems lens got stuck in the barrel due to external shock caused, Try out following steps-
  • If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move once's or twice then it will stuck again.
  • You can gently bump the camera to try to free the focusing ring.
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
Else contact Olympus, your camera need to be disassembled to get at the focusing ring at Service Center .
I hope this will solve your problem
Thanks..!!
Jul 04, 2011 | Olympus Mju 725 SW Digital Camera
Have a samsung camera that seems to be frozen. The lens is open but there is nothing on the screen. When pushing the power button the power light flashes, the camera makes a beep and the the power light...
Hi, this happened to my Samsung ST500, it took me months to find out what was wrong with it!, i found out the it gets stuck when the lens is different or has dirt in the lens.
  • I Got Mine working by cleaning the lens but if that dosnt work try this, mine started working when i dropped my camera quite high onto the ground which can make your lens pop back in if this dosnt work, try your warranty!:)
Oct 24, 2010 | Samsung DualView TL220 Digital Camera
Turn on power, green light flashes, powers off
Hi there its happens when the lens not ready for work. Some how its not able to stable his focus method. That's why its come out & go back. There is a chances of lens guide pin disturbed or damaged & thats why green light blinking continues. Its mean he inform you there is a system error. So please visit the service center for repair that. Thanks.
Apr 02, 2010 | Rokinon DZ1000 Digital Camera
Lens stuck, green Power light flashes, nothing happens.
get a butter knife or any thin object like that and use it to push out the lens and turning it on at the same time  you will hear a clicking noise which is normal  once completely out, use your hand with a gentle but firm presure move it form left to right
and then hopefully it should work after that
x
Dec 08, 2008 | Samsung Digimax S500 Digital Camera
Samsun s630 lens is stuck out, won't turn on
Apr 19, 2008 | Samsung Digimax S630 Digital Camera
Samsung S860 Digital Camera Logo
106 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
