I just recently purchased an LG Prada and have been having one hell of a time trying to set up MMS for pictures that I have taken and showing them to friends. Another huge issue has been setting up internet so that I can use email and just serf the web. It's an unlocked phone for both T-mobile and ATT but I can't seem to get them to work for either. Any help would be greatly appreciated!!!! Also I tried using this from ATT's web forum: http://forums.wireless.att.com/cng/board/message?board.id=mmode&message.id=12727&query.id=1307#M12727 I have also noticed that the 256 lg micro sd card that came with the phone is the only memory card that seems compatible. I used my 2 gb sandisk micro sd card and it doesn't register the memory card. Any assistance would be greatly appreciated. Thanks!
I use Gmail for my email account
Your post is helpful but I am still confused about the MMS and internet settings for both Tmobile and Cingular. Can you please break it down and separate Tmobile and Cingular's information for each set up. Also for Access point it just says blank and won't let me change it at all.
i have etouchJ168 mobile, i cannot received and send pictures through mms. what will i do?
Last nyt mu friend sent me mms but unfortunately i cant receive, instead i have recieved a message says tha... youve got MMS, we cant deliver it at the moment you may view it at smart.com.ph/MMS, how can i open it?
MMS and WWW configurations it's normaly a Operator issue. I sugest you try to contact the service provider.
***FOR MMS**** Under Connectivity - Network Profile, create a new profile Name: Tmobile Bearer: GPRS APN: wap.voicestream.com The rest just leave blank Then go to Message - Settings - Multimedia message - Network profile and make a new one Profile name: Tmobile MMSC: http://216.155.174.84/servlets/mms Internet mode: HTTP Proxy IP: 216.155.165.050 Proxy port: 8080 Connection: Tmobile Then go to Browser - Settings - Network profile - Activate Tmobile Name: Tmobile Homepage: http://wap.voicestream.com Connection Type: HTTP IP address: 216.155.165.050 Port number: 8080 Access point: Tmobile You should be done after that! Here''s the info for the cingular one. Do the same thing as the Tmobile one and just apply the information your "connection profile" should appear as below: APN: wap.cingular login:[email protected] (Must be in caps) pass:CINGULAR1 (Must be in caps) Authentication: None DNS1: 000.000.000.000 DNS2: 000.000.000.000 your "internet profile" should appear as below: Type: WAP Security: None Proxy Server: 066.209.011.061 Proxy Port: 9201 Login: [email protected] (must be in caps) Pass: CINGULAR1 (Must be in caps) Under your message settings, select the two profiles, and you relayserver should be:http://mmsc.cingular.com secure relay URL is blank. That should help you send and receive mms. This is a link to a tmobile site that will send you an mms: http://tmobileus.wdsglobal.com/phonefirst ****************EMAIL SETUP********* From the Start-up screen select the Main Menu icon -Select Message -Scroll down and select Settings -Select Email -Select Accounts -Select Menu icon -Select New Account You will now be required to enter some information relevant to your network provider and existing email account(I can find the pop and smtp servers if you let me know who your host is-I will use hotmail for example): -Account Name ? Hotmail -Email Address ? e.g. [email protected] -Your Name ? e.g. Bob Jones -Incoming Mail Server ? pop.hotmail.com -User Name ? e.g. bobjones -Password ? This is will be the same as your Hotmail password -Outgoing Mail Server ? smtp.hotmail.com You can also set up some Advanced Settings on your email account, to do this press the Menu icon and select Advanced Settings. You can now edit the following settings if you need to do so, however, they will already be set to default settings: -Protocol Type -Maximum Receive Size -Save To Server -Insert Signature -Reply Email Address -Incoming Port Number -Outgoing Port Number -Outgoing Mail Authen -Outgoing Server ID -Outgoing Server Password Once you have completed the above, press Save in the Email Account section activate your new email account. You are now ready to send and receive emails. You can also change your Network Profile and set up a Signature via the main Email menu simply select Network Profile then the new profile and activate. To set up a Signature choose Signature, then New and write your Signature and press OK
Pls i need the mms settings for TECNO TV50
Setting and reboot
I have a cricket samaung touch screen and cant recieve my multi-media messages can u help me please?
Ti ho inviato un MMS. Per visualizzarlo vai su vodafone.it entro 5 giorni, seleziona la voce MMS e inserisci il codice personale FIRENZE34
SOURCE: LG PRADA - setting up MMS and INTERNET
**FOR MMS**** Under Connectivity - Network Profile, create a new profile Name: Tmobile Bearer: GPRS APN: wap.voicestream.com The rest just leave blank Then go to Message - Settings - Multimedia message - Network profile and make a new one Profile name: Tmobile MMSC: http://216.155.174.84/servlets/mms Internet mode: HTTP Proxy IP: 216.155.165.050 Proxy port: 8080 Connection: Tmobile Then go to Browser - Settings - Network profile - Activate Tmobile Name: Tmobile Homepage: http://wap.voicestream.com Connection Type: HTTP IP address: 216.155.165.050 Port number: 8080 Access point: Tmobile You should be done after that! Here''s the info for the cingular one. Do the same thing as the Tmobile one and just apply the information your "connection profile" should appear as below: APN: wap.cingular login:[email protected] (Must be in caps) pass:CINGULAR1 (Must be in caps) Authentication: None DNS1: 000.000.000.000 DNS2: 000.000.000.000 your "internet profile" should appear as below: Type: WAP Security: None Proxy Server: 066.209.011.061 Proxy Port: 9201 Login: [email protected] (must be in caps) Pass: CINGULAR1 (Must be in caps) Under your message settings, select the two profiles, and you relayserver should be:http://mmsc.cingular.com secure relay URL is blank. That should help you send and receive mms. This is a link to a tmobile site that will send you an mms: http://tmobileus.wdsglobal.com/phonefirs... ****************EMAIL SETUP********* From the Start-up screen select the Main Menu icon -Select Message -Scroll down and select Settings -Select Email -Select Accounts -Select Menu icon -Select New Account You will now be required to enter some information relevant to your network provider and existing email account(I can find the pop and smtp servers if you let me know who your host is-I will use hotmail for example): -Account Name ? Hotmail -Email Address ? e.g. [email protected] -Your Name ? e.g. Bob Jones -Incoming Mail Server ? pop.hotmail.com -User Name ? e.g. bobjones -Password ? This is will be the same as your Hotmail password -Outgoing Mail Server ? smtp.hotmail.com You can also set up some Advanced Settings on your email account, to do this press the Menu icon and select Advanced Settings. You can now edit the following settings if you need to do so, however, they will already be set to default settings: -Protocol Type -Maximum Receive Size -Save To Server -Insert Signature -Reply Email Address -Incoming Port Number -Outgoing Port Number -Outgoing Mail Authen -Outgoing Server ID -Outgoing Server Password Once you have completed the above, press Save in the Email Account section activate your new email account. You are now ready to send and receive emails. You can also change your Network Profile and set up a Signature via the main Email menu simply select Network Profile then the new profile and activate. To set up a Signature choose Signature, then New and write your Signature and press OK.
i have the same pro. but i'm with rogers (canada) and i can't send photo msgs. to anyone do u have a solution?!?!?
I tried adding the network profile. However once I get to the connection part..I can't seem to choose t-mobile or manually put that in because it keeps saying empty and wouldn't do anything.
I can't seem to put anything in or choose from any option under the connection part.
I can't seem to put anything or choose from any option in the connection part. I put everything in fro the network profile except for the connection. What should I do?
can t sed or receving picture message
cannot receive or send photosÂ
Still doesn't work. even with after i put in all the info. won't let me add a new access point. it does but the name of the point(profile) comes up blank. the mms comes in but it shows waiting then retrieving but the image/pic mail never comes up.Â
hi i use yahoo mail, what are the incoming and outgoing mail servers for it?
my mobile phone is m12 cherrymobile
