I can not find how to get the scanner to read supplemental barcodes like the ones on the back of books. please help.
You should have a code book that came with the scanner, the code book allows you to program the scanner's options, the code book takes you step by step through the programming proccess. each option requires you to scan varios barcodes to "set" the various options one of the options will be to set the barcodes you wish to use, this is set to avoid a misread (confusion between barcode standards)
I found this code book (you will have to print it out as you cannot scan barcodes from the screen)
This allows you to program your unit to read & format how you want
http://support.symbol.com/support/search...
That helps a lot. I think I've been able to program my LS4000i but I still can't get any text to show up. I'm running Win2K and a PS2 setup.
