Question about Canon Office Equipment & Supplies
Older Canon Copier PC-6re
Get error code ''E0 00'' on flashing counter key. Anyone know what the code means?
  • Canon Expert
  • 1,326 Answers
Then Error code means that the fuser / fixing Lamp is blown or it could be the thirmal fuse is blown. It could also a bad thirmister, that may have caused the fuse to blow. One thing you can look at, will the fixing unit get warm or hot. Do you know any copier techs, as a friend. It is not a easy job to fix this problem. You have to fix it to clear it.... Good Luck
Posted on Mar 15, 2009
6ya staff
SOURCE:
What does the error code E000005-0000 mean?
This is a cleaning web end of life code. Replace the web and reset the counter in service mode. Press the additional function key, then the 2 & 8 at the same time, then the additional function key again. Press copier, counter, MISC, FIX-WEB, then OK. You might as well reset the WST-TNR setting as well. Check to make the waste toner bottle is empty - right side ,lower right of copier behind panel.
Nov 10, 2010 | Canon imageRUNNER 5570 Copier
I am looking for the owner's manual for a Canon PC-6RE personal cartridge copier.
YOU CAN GET IT FROM WW.GETMANUAL.COM FOR SMALL FEE PAID VIA CREDIT CARD.YOU EVEN CAN DOWNLOAD THE SERVICE MANUAL/USER MANUALGUIDE EVEN THE MAINTAINANCE REPAIR FOR CANON PC-6RE
Mar 28, 2010 | Office Equipment & Supplies
I have a Canon PC-6re copier. It is jamming
Use a thin but strong piece of card board (such as the back of a standard yellow pad notebook) and easily force feed it through machine. I had to use this method with our Canon Pixma MP190 printer. Hope this helps, Good luck!!
Feb 21, 2010 | Canon Office Equipment & Supplies
I have a Sharp AR-163 copier and it flashs U2 40. Does anyone know what the problem is?
Most commonly a toner cartridge issue. First try removing then reinstalling the toner cartridge and power off the machine. If this does not solve your issue then reset the error using the following:
Press these keys in sequence: #, interrupt, clear, interrupt. (screen should say service mode), enter 16, press print, it will ask are you sure? press yes.
This will reset the code so you can see if the code comes back
If it does then you have to change the toner, it has a defective crum (counter chip) on the back of it
Oct 21, 2009 | Sharp AR 163 Copier
I need a user guide for an old Canon copier model PC-6RE
You'll have difficulty finding that one, but really..... what is there you need to know?...it's as basic a machine as there ever was.
Apr 25, 2009 | Office Equipment & Supplies
Error Code E00002-01c0
you probably mean E000020-01c0 bad yellow drum codes in order 01Y 02C 03M 04B
Apr 10, 2009 | Canon imageRUNNER C3200 Copier
Serving my Canon PC-6RE Copier.
there are some things better left for others to do. copiers is one of them. you cant explain in a paragraph what needs to be done and how to do it. there are alot of things that can be broken by people who dont know what they are doing. your machine is so old that you cant get parts for it anyway. you would be better off getting a new machine.
Mar 31, 2009 | Canon Office Equipment & Supplies
Canon pc-6re error code EO 10
E010 Clock pulses fail to be generated or the PLL lock fails to be released due to a fault in the main motor, etc. Related drum drive unit and main drive unit
There is a problem with the motor of the drum or the main motor itself.
Nov 08, 2008 | Canon IMAGERUNNER 6570 Copier
Canon pc-6re
hi do this to reset the fuser unit:
go to service level one by pressing  *28* then copier --function--clear--error-ok
if that doesnot work either replace  thermistor
Best regards
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Aug 04, 2008 | Canon IMAGERUNNER 6570 Copier
224 people viewed this question
Clive
Clive
old marine
old marine
Ekse
