Check its main digital board. It might need replacement. If you wish to get more details, check the site linked
below. Pull up older posts there. Check
the site with patience, as it has over 2400 posts now. All are related to electronic equipment
repair help. If you search the site in
Timeslide option, which can be selected from the drop down list at the top left
of the display window, it will be easy to locate the related post. You can also do a search by type in the
brand name to your device into its search box at the top right of display
window.http://electronicshelponline.blogspot.com/
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Firmware update procdure to many popular brand TVs and others are givne.
If you wish to get more details, check the sites linked
here. Setup code list, and setup
procedure to many popular brand remote controls are given. http://electrohelponline.blogspot.com/http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic
/ Time slide, can be selected by the drop-down list, at the top left
of the display window, will make surf easy.
It seems you are using a set top box to access tv programs. I that case when a person changes the channel all the connected TVs will change. You should use extra set top box for multiple independent viewing.
When I power my TV on, no picture appears.. just sound. The screen appears to be black. I have to power on and power off my tv several times in order to see an image at all. Any fixes or solutions to this?
