When the system Starts, I initially see a 6' wide white Bar up and down the center of the screen with heavy, corse green and red snow on the rest of the screen. I assume the white bar would be the HP Logo being blurred. As soon as the set kicks to the tuner, the sound is on and the picture fades out to black. I have not taken the back off yet but I can hear a buzzing coming from the 3501Q00200A power supply. Where do I start?
Y-Sustain should be suspected. Make sure before replace it. If you wish to get more details, check the site linked below. Pull up older posts there. Check the site with patience, as it has over 2400 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window.http://electronicshelponline.blogspot.com/
SOURCE: hp parts
are parts for hp plasma tv as hard to find as ive been told need a y buffer upper board for 50 inch plasma
SOURCE: BLACK BAR
I had the same problem and HP has been very helpful, try calling this
number 877-917-4380 ext. 79 and be firm tell them this needs to be
fixed. They are sending my second replacement part and said they will
keep sending parts till it works, this tv is almost 3 years old.
Just to update this issue, HP has
now agreed to replace my plasma free of charge, they dont know how to
fix it and after a couple of tries they gave up and I'll get my new one
next Friday. For all of those trying , keep trying and don't give up,
don't take no for an answer.
Comment posted on Feb 04, 2009Just
an Update here, My new plasma arrived on Monday free of charge, no
shipping, no money at all, works like it did when new. Call HP with the
number listed and let them have a piece of your mind, you will get
results.
SOURCE: My HP PL4260N powers on and we can hear the
What is the last thing that happened before this problem occured?
SOURCE: hp plasma tv lost picture
Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the left top left corner of the display window. It will make search easy. Some times, the ads attached with each posts both at the right and bottom, might help you to find the availability of spare parts. There are more than 640 posts to different brand TVs now. Will be updated daily.
