I drop my iPhone 4S and it just shut down and won't turn on unless you plug it
SOURCE: I dropped my iphone 3g
Check the 2 pins connected on the home button if touch the interface of the board,might not hitting that is why the slide unlock not working.
SOURCE: My g1 randomly shuts off...its charged..but won't
All you have to do is change the battery,in this case,battery don't have enough performance to save power and can not distribute current on the phone that's why it direct rely on the charger,when you see your battery is already deform its shape,expect low performance on your phone as well as easily got low battery level.
SOURCE: iphone shuts off and won't turn back on what do i do?
You might try holding down the power and home buttons at the same time.
Wait until you see the silver apple. Thats what I did when mine
wouldn't turn back on.there is an easier way instead of just guessing....
when you plug it into any form of charging source...just completely shut
down your iphone...and leave it there for how ever long it takes to
charge...(to be able to use it again is about 30 minutes)depends on your
energy sourceFirst open iTunes and Conect your iPhone cord to your computer, but do
not plug it into your iPhone. Then press and hold the home button on
your phone while conecting the iPhone cord into your iPhone continue to
hold down the home button. Then click restore in iTunes
SOURCE: iphone won't turn on
Hi
What happens when you try to charge the device?Won't charge?Switch chargers.
Try hard resetting it and see what happens.Here's a video tutorial on how to go about it.
Hope it helps.Thanks
SOURCE: my samsung doubletime won't turn on unless it's plugged in
REMOVE BATTERY > Clean the terminals specially middle terminals of both battery & phone with dry cloth.install battery. If the problem persist then change battery.
