My ps2 is great but then the disk stopped spining nothing moves h
Plea help me reply your answer!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
If your spindle has stopped spinning, it will most likely be 1 of 2 problems. Either your spindle motor has burnt up, or even though it is very unlike, a lead wire that supplies the power to the spindle has became disconnected. Now, if the case it the burnt up spindle motor, there are hundreds of motors for every kind of PS on, of course, E-Bay. If the problem is for some reason, a soldered wire has broken from the motor. It is very simple to re-attach the lead with a quick touch from a soldering iron. I hope this has helped.
I don't want to put you down or nothing but, buying the slim ps2 wasn't a great idea. If you bought the original ps2 it would've been better. The thing about the thin ps2 is the hd is small, the laser tends to become weaker faster. Go get the ps2 checked out someplace.
what you might want to do, is go to radioshack and buy a lens brush disk. i had the same problem and it really works, the maxell one works too, but if you get the radioshack one, there are 6 brushes instead of 2. Hope i helped!
Don't bother changing the lens. If i understand you correctly you have damaged the motor or some circuitry leading to it.
I hope this helps! good luck on finding a new one, they are abundant right now!
stops spinning when starting up
