Just reloaded new ink cartridges. The printer doesn't have 'power' -- light is on power supply and scanning bed, but not on control panel. The print head is to the far right. I need to move it so I can remove the ink cartridges... have to ship the printer to Kodak. Since I just loaded new ink cartridges, I would prefer to keep them -- and I don't know if it will leak when I pack up the printer.
SOURCE: not recognizing new ink cartridge
We had the same problem and tried all steps Customer Service suggested each time; after several calls, it was determined we had a defective printhead... Kodak sent a new printhead, new ink cartridges w/ an envelope to return the ones I was using.
Apparently it's a common problem with this model; especially the earlier ones. Have had NO problems since the printhead was replaced.
I would suggest if you have recurring problems (even after Customer Service directives), call and ask if you might have a defective printhead.
SOURCE: The Infamous Kodak 5300 "Printhead Missing or . . ." Error Message
How do you install the update as the updater will not work until the fault has been cleared!
SOURCE: Can't load the Kodak AiO Homecenter software
Go to the control panel and uninstall it. Don't just delete the program from windows explorer. Reinstall everything. It SHOULD work fine.
SOURCE: Kodak esp 3 all in one. colour prints come with purple tint
Surely you can turn the flow of ink down via your settings
SOURCE: My Kodak ESP 3 all-in-one printer will not print
you may try to clean the printhead and recalibrate the printer. if this will not correct the problem, you need to replace the printhead. I suggest contacting Kodak technical support to have a replacement printhead.
