Proform 380 Treadmill Walking Belt Logo
Posted on Mar 15, 2009
When i run on my treadmill it slows down and then back to norm
Ken Swan
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on May 13, 2009
Ken Swan
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
Helped
26254
Points
30
Go to:
http://www.iconservice.com/manuals.html
fill out form......search.... view manual in PDF Format
Print
Why is the treadmill slowing down when you walk on it. It slows down when someone get on the machine.Is there a way to adjust the belts or anything that can be done to rectify the problem.
You have adjust the running belt of the treadmill. If you check the bellow added link you can find out how to adjust the running belt of treadmill. Almost all treadmill follow the same procedure. So if your brand mode is not listed you can follow the procedure of listed treadmill.
http://electro-medical.blogspot.com/
When i start my proform 750 it doesnt slow down. It goes straight to max speed and never slows down.
try to calibrate the speed on the treadmill look in the trouble shooting section of the manual
Precor 9.27 treadmill won't slow down
Hi, It's probably the speed censor. Clean it up and should be good to go. When you disasemble it clean all other parts and put back togeather. Good luck
Elite ef 9213 treadmill slows right down but does not stop after 3 minutes
LUBe the deck belt inmediately in according with the instruction manual maintenance, you have some deck belt worn. 2) Inspect the drive belt for replace.
RUN THE SOFTWARE CALIBRATION for diagnose and troubleshooting.
sincerely. God bless you
My candence Dx10 slows down after using for a 10 min or so
Dear Sir:
You must need to adjust the sensor speed, by that reason Please RUN the software calibration Inmediately for easy diagnose and troubleshooting.
Otherwise see my personal TIPS, for diagnose and troubleshooting.
Sincerely. God bless you
ernesto cuadra
managua, nicaragua. c.a.
PROFORM RUNS BUT WHEN I STEP ON IT EITHER SLOWS DOWN OR STOPS MOVING AT ALL
Belt needs tensioning up on its adjusters or the motor drive gear has come loose and needs tightening back up.
1helpful
Treadmill slows down and stops
hi..probably the reason to this problem may be due to
worn belt and deck or a belt that needs lube.
check it out..
thank u..
kindly rate my response..
Treadmill slows down Free Spirit Mod.#122300800
make sure you are not in a program. Can you speed it back up?
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Top Proform Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
john h
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
