Hello Sharon, 1. Do the documents satisfy paper specification? 2. Have the documents been jogged? • Align the edge of documents for stable paper feeding. • Remove documents with crease or dog-ear. • Scanning different width of documents may cause skew and result in paper jam. 3. Are Chuter Unit (ADF paper chute),Guide P ASSY (Sheet guide), Feed roller cover (plate guide) and Brake roller cover installed correctly? 4. Clean the Feed rollers, Eject rollers,Plastic rollers, glass surface and paper feeding surface, and see if the error is resolved. 5. Replace Pick roller or Brake roller, and see if the error is resolved.Check the consumable counter from the TWAIN driver screen or from the built-in Maintenance mode. When the counter exceeds the values, replace Pick roller or Brake roller.
When a document jam occurs, "J" and "1" will display alternately on the function number display panel of the scanner.Please perform the following:
If document jams occur frequently, please check the followings:
6. If the issue still persists, then you are recommended to contact the nearest Fujitsu service center for further assistance.
Hope the above information is helpful.
Thanks & regards,
ScanCare
