Spa Parts Plus GFCI, Circuit Breaker, 30 Amp Logo
Posted on Mar 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Gfci breaker for spa
50 amp breaker keeps tripping, older hot tub,new gfci breaker, new wire, new gronding rod,etc. installed new control board, checked all connections, to incluce ground wire to motors, can isolate the gfci,bypass( jumper wires to contol), everything runs fine...reinstall gfci, the breaker trips, any ideas?
  • Thomas F. Schneider May 11, 2010
    Pump motor partly shorting out?
Anonymous
Level 2:
  • Expert 44 Answers
  • Posted on Mar 24, 2009
Anonymous
Expert
Level 2:
Answers
44
Questions
Helped
19508
Points
124
Gfci's are designed to trip if they receive voltage on there ground/neutral side, therefore my vote is for Smithbrother I would say there is probably a partial short somewhere in you system.
I have a spa berry 2 person hot tub. Tried resetting it but as soon as I let go of the reset button it trips the breaker. Can't get it to stay on. Tub is 4 yrs old. Where do we start?
Melisa, Breaker/GFI may be going bad. You may have to get an electrician to check for short or faulty motor/heater, etc. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://ehottubsandpools.com/?p=320
Troubleshooting tripping hot tub GFCI breaker
Hot tub GFI keeps tripping
Spa Circuit Breaker Mysteriously Tripping Any Clues Portable Hot Tubs amp...
Jun 27, 2016 • Pool & Spa
My hot tub trips the GFCI. THe GFCI holds when I disconnect the wires running into the hot tub. I have disconnected EVERYTHING from the circuit board including the heater and the GFCI still trips.
Sounds like wet or bad wiring somewhere but u should do a visual inspection of all the wires & connections first then through process of elimination. Turn off breaker disconnect all wires and connect one wire then turn breaker on & if it dosent pop the. Turn it off and connect one more wire and turn the breaker on & continue until you get the breaker to pop and the last wire or board u just connected is your problem & go from there.
Feb 14, 2016 • Pool & Spa
I just wired my hot tub into my new house. And GFCI keeps tripping?
Still would go with Miswired.
if this is an auxiliary GFCI Spa Disconnect,
240 VAC, 50 Amp, then...
All of the following needs to be this way:
  • 4 wires from MAIN Circuit panel, into GFCI disconnect box, 2 hots, 1 Neutral, 1 ground
    • 2 hots go onto the disconnects Power Bus Bar for breaker
    • 1 white Nuetral goes to Isolated nuetral bus bar
    • 1 green Ground goes to ground lug directly on the box
  • 1 GFCI in the auxiliary disconnect box
    • The White Pigtail of the GFCI Breaker goes onto the Isolated Nuetral bus bar. There are now two wires there.
  • 4 wires come into box from Spa. (Unless the spa is Specifically a 3 Wire Connection Spa!)
    • 2 Hot/Line wires will go into the L1 & L2 lugs of the breaker respectively.
    • 1 White Nuetral Wire will go into breaker as well at the "Load Nuetral lug, usually marked as 'LN'.
      • It will NOT go on the Isolated Nuetral bus bar.
    • Green Ground wire will be connected to ground lug, 2 wires are now connected there.
  • Connections at spa will be respectively connected: the 2 hots on line 1 and line 2. White wire goes to Nuetralnd green ground will go to a Ground Lug, most likely to metal control box.
If it's not wired in this manner, it is wired WRONG.
2answers
Hot tub breaker trips but only when people are in it?
Because it is a GFCI. Try making sure that the grounds are all good. Maybe go the extra step of putting in grounding rods into the ground and grounding to the unit. These are just guesses.
2answers
Just replaced the circuit board, it has power but fuses keep blowing when we turn on gfci breaker
This is happening when you first activate the GFCI then either the circuit board is installed incorrectly or it is bad.
US Parts Center
Breaker for hot tub keeps tripping
Leaking heat element.
2 GFCI on same circuit.
Rat-chewed wire. Inspect wiring.
Nail through wire.
Melted wire nut in junction box.
Undersized wire and breaker has been overheating breaker, and breaker has gone bad.
Shorted breaker. Move wires to different same-size breaker.
http://waterheatertimer.org/How-to-wire-GFCI.html#2-pole-gfci
http://waterheatertimer.org/Color-codewire.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 21, 2013 • Pool & Spa
1helpful
Qo260gfi not tripping
Question is not fully clear.
2-pole 240Volt gfci circuit breaker requires the white wire be connected to neutral busbar.
Easy solution for 240Volt spa that comes with gfci:
Replace spa gfci with regular non-gfci breaker.
Install 2-pole GFCI breaker in main panel, and connect wire to spa breaker.
Having 2 breakers is not a problem.
Having 2 GFCI on same circuit is a problem.
Apr 18, 2013 • Pool & Spa
What's youI just wired in my J-300 Jacuzzi hot tub. The GFI trips every time I reset it. I took the GFI out of the equation and the tub runs fine, does not trip the breaker at the main breaker box
#1. DO NOT GET INTO TUB FULL OF WATER WITH A GROUND FAULT.
2. There is a short. You need to get multimeter and start checking each part for current running to ground wire.
3) Power is ON. Connect power without GFCI.
4) Tape tester leads to wood sticks to keep hands away from power.
5) Do not touch anything directly or you will become the ground rod.
6) Ground wire must be present, and bonded back to main panel box.
7) Do not sit or touch directly on cement or bare ground. Do not touch or lean into anything made of metal.
8) Body and parts must be on sheet of plywood, or similar non-conductive dry surface.
9) Test each part with spa, but also test electric line coming from main box.
10) GFCI will also trip with any fault detected on line. So the wire coming to spa may have the fault.
11) Add a new dedicated line from main box to spa.
http://waterheatertimer.org/See-inside-main-breaker-box.html
40 amp gfi on hot tub keeps tripping.I have a 50 amp.can I use?
Your hot tub needs GFI protection because it is electrical, and people sit inside water that could be exposed to electric current.
You have a fault to ground that needs to be fixed.
Size 8 wire for 50Amp breaker.
Size 6 if tub is 50-100' feet away
6helpful
My hot tub keeps tripping the breaker and will only stay on for a short period of time before tripping the breaker. What can I do?
Check for a water leak in the electrical areas of your spa... specifically look closely around the heater terminals, look for wet and corroded connections... If this spa is wired to a plug-in outlet, look at the GFCI plug assembly as well... You can also try disconnecting the blower, pump, heater, etc, from the control pack (one at a time) to determine which item is causing the tripping.
Top Spa Parts Plus Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Spa Parts Plus Electrical Supply Expert? Answer questions, earn points and help others
