Question about Toshiba SD-V57HT System
Disc Read Error
A relative of mine has a Toshiba DVD/VCR Home Theater System SD-V57HT and though it's only about a year old, it's been giving her problems. Every time a disc is inserted, DVD or music disc, a message pops up on screen that says 'Disc read error' and then the disc tray opens back up. If anyone has had this happen before and knows what the solution is, please let me know. Thanks in advance.
  • Anonymous Jan 06, 2008
    my Toshiba dvd player will let you loead the disc but then Disc Error pops up on the screen.
  • 35 Answers
This is the problem with your dvd player's lance so you need to repair it from your Toshiba DVD/VCR Home Theater System provider. and after replacing it u have to take care of it. do not use crashed disks . Use lance cleaner liquid to clean lance .
Posted on Aug 11, 2007
6ya staff
SOURCE:
No Sound
They mess up the lazer in the unit, it is verry costly to have it repaired, Just get a different one,
Dec 05, 2012 | Toshiba SD-V55HT DVD/VHS Home Theater...
Hello, I have had my Home Theate packed for a few years now. I have 2 Toshiba remotes. Neither of them operate the system. One is an SE-R0094 and the other remote is an NB001. I tried new batteries in...
The SE-R0094 is the original remote for the SD-KT50. So should work with it unless it's faulty.
You can get the service manual for the SD-KT50, that might give you clues as to why it doesn't work. It's free the manual, just type the model number into Google.
Jul 06, 2017 | Toshiba SD-KT50 System
I wanna buy some speakers wires for this system i cant find them anywhere7067676412 if you have them
Even if you can find them they'll probably cost a relative fortune.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Toshiba-SD-V55HT-Home-Theater-Systems-manual/id/284ag007/t/2/
Page 13 shows the wiring scheme.
The wire itself is just glorified lamp cord. Go down to Radio Shack or the hardware store and buy 100 feet of 18-gauge lamp cord and make your own - cheap.
Maybe bring the unit down to an electronic store and see if they have any compatible ends to match the proprietary outputs.
There are a couple whole non-working SD-V55's on eBay for under $60 delivered. If you check with the sellers to make sure the have the cables maybe you can work a deal.
http://cgi.ebay.com/4K33-TOSHIBA-SD-V55HT-HOME-THEATER-DVD-WORKS-FM-WORKS-/140508685542?pt=LH_DefaultDomain_0&hash=item20b6f864e6
http://cgi.ebay.com/Toshiba-SD-V55HT-Home-Theater-Receiver-DVD-VCR-PARTS-/160492805226?pt=Home_Theater_in_a_Box&hash=item255e1ddc6a
From what I've seen asked for proprietary cable sets, these would be bargains.
Feb 19, 2011 | Toshiba SD-V55HT System
When I put a DVD in the player it gives a "no Disk" message.
I had the SAME problem, and all that was needed was for the laser lens to be cleaned. They have laser lens cleaning discs at Best Buy (that's where I got mine) and probably just about any electronics store that sells/repairs DVD players-- mine cost about $16. You pop it in, it spins and cleans the laser lens, and then your discs are able to be read properly. Hope it helps-- it worked for me!
Sep 06, 2010 | Toshiba SD-KT50 System
Sd-v392 claims incorrect disc on most dvd`s
I removed the cover,the dvd unit and cleaned the laser lens with alcohal. The two back screws were loose on the dvd unit. It`s working like new again.
Sep 18, 2009 | Toshiba SD-V392 DVD Player/VCR
Disc read error
Dear Sir,
After 2-3 years generally all optical drive lenses goes bad,so first try by cleaning lences,if it not solves your problem then try by replacing lence of your DVD Drive,if you have any problem regarding this issue leave a feedback we will glad to assist you.
have a nice day
good luck
Sep 11, 2009 | Toshiba SD-P1900 Portable DVD Player
Toshiba reads no disc
Dust infiltration is a likely culprit. Unplug the unit, open the case. Take a cotton swab and wet it with a small amount of glass cleaner. Gently wipe the laser lens several times without applying pressure, then use the other end to finish cleaning it off and to dry it. Often, so much dust gets inside these units and coats the objective lens it can't see the disc anymore. Give it a try, might work after this operation. I've fixed many CD & DVD players this way. If that doesn't work, take a can of compressed air and blow out dust from inside the laser by pointing the nozzle to the open space between the lens and the lens cover. Hold the can at least three inches away so as not to damage the internal workings of the laser assembly. Several short/sharp bursts of air might dislodge dust that has accumulated inside the laser housing.
Mar 05, 2009 | Onkyo DV-S535 DVD Player
This system stopped playing DVD with a very slight use
1. An unplayable disc is inserted. 2. The Rating level is set, Cancel the Rating function or change the rating level. good luck!
Jan 12, 2006 | Toshiba SD-V55HT System
Toshiba SD-V57HT System Logo
212 people viewed this question
Top Toshiba Audio Players & Recorders Experts
 Grubhead
Grubhead
JohnLong
Blake Whiteside
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
