Ok, so I have an Xbox 360 Elite and i took it to a hotel this weekend and when i got back to the T.V. I normally play on when I start it up the screen flashes black for a second and then goes to a blank channel for five and it never shows any of the dashboard or game. I have tryed both the regular and High-Def plugins and it does the same thing. Also, when it does flash black the fan sounds like it is spinning even faster than normal
Thanks.
SOURCE: while playing xbox 360 in 1080p mod, the screen frequently blanks
Most TV's have problems doing 1080p over component. Dial the Xbox back to 1080i. Make sure the big switch on the Xbox AV cable is set to 'HDTV' not 'TV'(common problem) If the problem persists, try plugging into different hookups, use HDMI (if your console supports it) or buy one of the HDMI adaptors from PDP or MadCatz if your console doesnt. HDMI will reduce the clutter and will make 1080p a reality.
SOURCE: i am trying to
are you attached via hdmi.if yes then may setting does not match. please try to conect via A/V in put.there must sound come.
SOURCE: Sharp LC37D44U Power LED was flashing green. TV
I had the same problem. all the service reset would only make the display come on for a few second with no "k" on the screen - only the channel would show up. I purchased a complete set of board for the lcd on ebay, and started swapping them one by one. The inverter boards were the culpret. Tele working 100% since that board swap.
