On our NAD 7130 receiver when I select some of the stations that are dead on... (thanks to the cable) and in memory. I often get no stereo signal.
To get the stereo light to come on (So it comes in stereo) I have to seek a station that gets Stereo signal and then I can re-select the station in memory to get the stereo signal.
Really annoying. (The same thing happens with the antenna only) Besides that it works great.
The contacts in the A B speaker selector switch had degraded on my NAD 7130 receiver. Distortion and signal loss would come and go. Contact cleaner and wriggling the swx knob became useless. Then, years ago I jumped the swx with small lengths of bare wire and tinned the whole thing with solder. Never had a problem since and it probably improved the receiver because it eliminated a component in the output stage that could (and did) introduce distortion.
37
Chapter 6:
Using the tuner
Listening to the radio
The following steps show you how to tune in to FM and
AM radio broadcasts using the automatic (search) and
manual (step) tuning functions. If you already know the
frequency of the station you want, see Tuning directly to a
station below. Once you are tuned to a station you can
memorize the frequency for recall later-see Saving
station presets below for more on how to do this.
1 Press the FM/AM button to select the tuner.
2 Use the FM/AM button to change the band (FM or
AM), if necessary.
Each press switches the band between FM and AM.
3 Tune to a station.
There are three ways to do this:
Automatic tuning
To search for stations in the currently selected band,
press and hold TUNE ?©/?? for about a second. The
receiver will start searching for the next station,
stopping when it has found one. Repeat to search for
other stations.
Manual tuning
To change the frequency one step at a time, press
TUNE ?©/??.
High speed tuning
Press and hold TUNE ?©/?? for high speed tuning.
Release the button at the frequency you want.
Improving FM stereo sound
If the TUNED or STEREO indicators don't light when
tuning to an FM station because the signal is weak, press
the MPX button to switch the receiver into mono
reception mode. This should improve the sound quality
and allow you to enjoy the broadcast.
Using Neural THX
This feature uses Neural Surround™, THX® technology to
achieve optimal surround sound from FM radio.
• While listening to FM radio, press AUTO/DIRECT for
Neural THX listening.
