Machine stuck on drain in rinse cycle, motor running, water has drained but won't progress. Reduced & redistributed load, did not assist. Only way to turn off is at powerpoint. When turned on at powerpoint it continues in drain mode (motor running) lights are off, and when machine is turned on the short wash, rinse light, slow & hold spin lights are on and it beeps every second!
SOURCE: my washing machine wont drain the water
Sounds like a blocked pump.The pump could be burnt out.
SOURCE: Fisher & paykel top load washing machine
We had the same problem with our washing machine being full of water and beeping during the rinse cycle. The problem is that the filter, which is located under the washing machine, is plugged with something. Ours was plugged with a cotton swab. You have to tip the washing machine up and remove the filter and unplug it. The filter is in the center of the bottom of the machine. It twists off. I had to get the cotton swab out of inside the machine through this opening.
This machine plugs up a lot - I've never experience this with any other washing machine. Good Luck!
SOURCE: Stops drains and bleeps with only spin light illuminated
It sounds like you need to re programme the
machine.
With the machine plugged into the wall and
turned on and the headset turned off this is what
you do.
Push and hold down the start button, while doing that you need to then push and hold down the power button.
Hold them down for about 5 seconds, during
which time you may a series of up to 3 beeps.
Then release the buttons.
Turn the machine off and then on again followed by the start button. Allow the machine to then run the complete cycle.
This should correct your problem, if this doesn't then you may need to then look at replacing the computer panels.
SOURCE: Fisher& Paykel fault 37 - on large loads water
the programer has given up the gost on you only thing you can do is try to replace it,,,
SOURCE: fault with my fisher & paykel GW708
i found with mine i had the same fault and it only happened on cold ( i only wash with cold and have hot tap turned off) when on spin it would continue to fill and if i turned the tap off and back on it would stop. this means it is a sticky solonoid valve. remover the controle panel. leaver the solonoid coil off the valve. use needle nose pliers in the little slots to unscrew the valve counter clockwise. check rubber isnt split. if it is replace. clean out and re assemble. if the problem persists and you only use cold like i do swap the hot and cold solonoid over. hope this helps
