Had a leaking blue elbow on gwl15 washer. How to seal the part
SOURCE: Fisher and Paykel washer dripping water into tub.
Dear FixYa Customer,
First and Always go to the Manufacturer for Parts Compatibility and/or Service!
For a GREAT APPLIANCE PARTS WEB SITE click on the highlighted http:// link that follows...
Same-Day Shipping, Return Any Part
Save When You Do Repairs Yourself! @
http://www.partselect.com/Entry.aspx?
jackiaria
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
SOURCE: Fisher & Paykel GWL11 Leaking water
If you cannot see the water leaking from the inlet valves, check the seal just above the water pump located directly under the drum. I am in the midst of awaiting parts to fix this very thing on my FP GWL11. This leak is dripping water directly onto the motor, causing it to trip the circuit breaker during drain/spin cycles.
Note... I have also had to have the inlet valve assembly replaced as well as it was not opening to allow cold water to mix with the hot.
Hope this helps.
SOURCE: Fisher/Paykel GWL10US washer. Blinking hot and
When they say replace the valve There,s a very good chance the diaphram is the valve is purferated or split (common Problem).But you can Remove the coil from this & with pointy nose plyers you can unscrew the top & inspect the diaphram If it,s ok give us a bit more info Hope this helps.Cheers.
SOURCE: fisher and paykel gwl15 leaking water from under
If it is leaking during fill cycle then it is probably the fill tube. If it is leaking when it drains it is probably the drain hose on the bottom of the drum. If you do not know when or where it is leaking from get a piece of card board and put it under the machine and run the cycles checking the cardboard between each cycle to find out when and where it is leaking from.
