this error more related to software problem,but you need do below step to check their hardware is in good condition.if all ok no problem,you may need to reformat their OS
1.off machine/on machine
2.pls check their controller connection (in you left side back cover down area).Make sure all the port are plug in properties and also in correct location,you cannot plug in to anywhere if no you will get the error code.
3. open fusing door ,try to unlock screw on right side back cover got 3 screw (torx 15 or 20)
4.open that cover look down that area got 1 big spider board.make sure all their connector usb port are plug in properties and in correct location.
5. check the big board should be got 3 LED green light stable on if no use machine.no got red LED on.
6.check that small board are properties install in good position in big board location.
7.check that small board must go 1 LED green light always falshing or stable,if got Red LED light on means this board faulty need replace new unit.
This error more related to software problem,but you need do below step to check their hardware is in good condition.if all ok no problem,you may need to reformat their OS
If set powers up for a few seconds (green power light) and goes out do the self check the model indicated has:
On front of set (not with remote) press and hold both the input and menu buttons for at least 5 seconds and release both.
Green power light will blink a two digit error code like 2 blinks, 2 blinks a pause and repeat it several times.
Let me know what error code you find (if you have unplugged the set that will clear all errors and you have to plug it in and try to turn set on again---when it fails do the self check)
Model number given indicates it should be a 2000 year model.
If so, it should have the self check feature; try to turn the set on and when the green light goes off: On the front of the set press and hold both the menu and input buttons for at least five seconds and then release both buttons.
Power light will blink a two digit error code like: 2 blinks,pause and 2 blinks (2,2 error code is most common one). It will repeat the error code several times.
Let me know what error code you find and I will tell you what it may mean.
if this told you something you did not know rate this solution as "very helpful" as I do this here for free.
Hello Hello, you name the error really is not on the list, the more like these and here is what it says to do. A greeting and let me know if you have been useful Formatter internal RAM or ROM error
Light pattern 3 LIGTHS ON, STABLEFormatter internal random-access memory (RAM) or read-only memory (ROM) error.Action
Unplug the printer and plug it back in.
Unplug the printer, remove any optional memory, and turn the printer back on.
