Sanyo DP50747 50 in. Plasma TV Logo
Posted on Mar 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ysus board number for a sanyo 50'' plasma model dp50747
Can someone please give me the model number for the sanyo 50'' plasma dp50747.
  • Anonymous Mar 14, 2014
    Where do i locate the pairing code for my sanyo model dp50747
  • Anonymous Mar 28, 2014
    can i order a remote for a sanyo model dp50747
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 01, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1792
Points
This is a Sanyo Vizon 50" plasma the model number is DP50747 .. hope this helps the website for this product is www.sanyoctv.com and the phone number is 1-800-877-5032
Anonymous
Level 1:
New Friend:
  • Posted on Mar 21, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1792
Points
I just bought a Sanyo DP50747 50 inch plasma. When I pause the tv, then push play (even 1 minute or less) the sound does not start as soon as the picture starts back. I have picture first and no sound for 4 or 5 seconds then the sound continues from that point.
CoppellTVRepair.com
Level 3:
  • Sanyo Master 778 Answers
  • Posted on Feb 13, 2012
CoppellTVRepair.com
Sanyo Master
Level 3:
Answers
778
Questions
0
Helped
396476
Points
1847
The YSUS board of Sanyo dp50747 is LJ92-01516F and it is known to fail.
Hope this helps...for more see our site or blog:
http://www.coppelltvrepair.com
Anonymous
Level 1:
New Friend:
  • Posted on Oct 09, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1792
Points
50 sanyo hdtv model dp50747 with a black bar or colored lines about 1 wide down left side of screen. I have checked all the ribbon cables and made sure all were tight and good conection. What next?
Definitely drivers, and may or may not be repairable. Here is what I understand. It depends on how the plasma panel in that set was made. Some panels have the X-drivers on a separate board. Others bond the drivers to the plastic ribbon connected to the panel. If it's a separate board, the board can be replaced. If it's bonded to the ribbon, it's virtually impossible to replace the defective chip.
Dp50747 has vertical 2 inch wide black row with a green line up the center, which card might be at fault? thanks
If you have JUST two green lines then your choices are between the buffer boards, YSUS board (all boards on the LEFT side of the TV when looking from the back) and , less likely, the main or plasma controller board. I'd really focus on the first two.
if you have two lines ON TOP of otherwise normal picture then you most likely have a bad panel, specifically the address register ICs embedded in the display's fabric underneath the display ... there's no solution to that I'm afraid.
Will not comr on
That can be caused by a number of things. Power board, main board and sustain board - usually YSUS - are at the root of it.
Open the TV and look inside, then get back for some more detailed troubleshooting tips.
We have a number of options available depending on which version of the TV you have and what's inside. Check at
http://www.coppelltvrepair.com/search?Q=DP50747+&As=false&Pf=&Pt=&Sid=false&btnsearch=Search
Tv just went off
Sanyo DP50747 has about a gazillian completely different implementations.
Some of them have Samsung boards inside, some have LG boards inside and yet another one has Panasonic boards inside.
Samung sets have known problem with the YSUS sustain being killed by a failing buffer board, the LG ones with the YSUS and ZSUS sustain boards, the Panasonic ones with the power board, which reminds me the previous two also have known issues with the power, but not nearly as common as with the sustain/buffers.
Main board is also known to cause issues in the Panasonic-driven models.
All in all it is essential to know which chassis (model) you have in order to provide any meaningful help.
You can also try searching at www.coppelltvrepair.com/search for various repairs or replacements offerred for DP50747.
Model # DP50747 are all 5 fuses the same? where can I get a list of parts?
Sir it has different types of rating it is commonly printed in the main board or printed exactly at the fuse. The parts try to check this link http://www.shopjimmy.com/sanyo good day and best regards.
2helpful
I am trying to locate a fuse for a Sanyo plasma model number dp50747 it is the fuse right next to the power suppl. it shows ft10ah250vp on the fuse
thats a 10 amp fast blow fuses rated for 250v
You can get them at any Radio SHack Store
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
2answers
No video but audio is fine on Sanyo 42" DP42746 TV
If you unplugged the Ysus board, then you need to replace the Ysus board, or both sustain boards. This is the part: The part is often available on Ebay, or from manufacturer. Look also at Vance baldwin or Partstore. To do a good job the Sustain boards should be tested by a tech , following service manual. It is almost for sure sustain board by the way.
Sanyo DP50747 50" Plasma sound but no picture green light is on.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
