Nikon COOLPIX L3 Digital Camera Logo
A
Anonymous Posted on May 10, 2013
Lens error repair - Nikon COOLPIX L3 Digital Camera
CameraR
Level 3:
  • Nikon Master 4,738 Answers
  • Posted on May 11, 2013
CameraR
Nikon Master
Level 3:
Answers
4738
Questions
Helped
1195834
Points
12483
Here's a video showing troubleshooting steps for this problem
And here's a page summarizing these steps:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
My Camera lens trys to open but wont.
Lens stuck, is common defective that need new lens unit replacement or just repairable.
Causes of a Lens Error: There are a number of ways with which a lens error can be caused. Particulates might have managed to get into the mechanical bits that allow the lens to retract, a purely physical interference with the lens mechanism. If the camera was dropped, especially while the lens was extended, there's a pretty good chance something might have been knocked loose, such as the guide pins upon which the lens withdraws and retracts.
How to Repair a Lens Error: As scary as a lens error might seem, there are some easy fixes. Before trying any of them out, however, first take a good long look at your camera warranty and maybe have a chat with the company. If the lens error will be covered under the terms of the warranty, go for it. Even some of the simple fixes mentioned below might void the camera warranty. Frankly, however, it's unlikely that a lens error will qualify for the warranty.
Additional details could find in this article link: fixing-lens-error-on-digital-camera.html
Keep us updated.
Lens error
Keep us updated.
2answers
Lens error says restart camera how to restart canon S3iS camera
Hello
Unfortunately a "lens error" message is not something that you will be able to fix. This error indicates a system failure and requires the camera to be sent in for servicing and repair.
2answers
How do i fix the camera because it tried the things you guys said but it still doesnt work..can you guys help me please..when i try turning it on it says lens error restart camera
Lens error usually comes up when something is impeding the lens from moving. Usually this happens when something has gotten stuck between the sleeves of the lens or if the camera was dropped on its lens, causing the sections to get jammed on an angle.
The best thing to do is to call a Canon Repair centre or 1-800-OK-CANON to have your camera sent in to be repaired. If the camera is still under warranty and the cause of the lens error wasn't your fault, you won't be charged for the repair. If it was due to customer error, you will be given a quote for the repair costs before having the work done.
2helpful
2answers
1helpful
2answers
Canon SD 870IS - lens error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Lens error, restart camera
Try to unstick the lens by gently pushing it in or pulling it out a little bit. IF that fails, the gears are too misaligned to repair it without opening it.
If you're out of warranty, there are third party place that replace them such as camera lens repairs.
If you want to do it yourself, there are also free camera repair guide websites that show you how to replace the lens, the replacement part is usually available on ebay.
Casio Z750 says, "Lens Error" on start up, and then shuts down?
A lens error has to be sent into repairs or else you need to buy a new camera. Repairs is 800-706-2534 and then choose extension for repairs.
2answers
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
